<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help Needed – SRS Airbag Fault (B00012A) Still Not Fixed After Replacing ECU and Using VDASH]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I’m really hoping someone here can offer insight because I’ve tried everything I can think of, spent a fortune, and I’m still stuck with a non-functional SRS system and other VDASH-related problems.</p>
<p dir="auto">⸻<br />
The Core Issue:</p>
<p dir="auto">I’ve been trying to fix a persistent SRS airbag fault (B00012A) on my Volvo XC90 (driver’s airbag circuit range/performance). So far I’ve:<br />
•	Replaced the driver’s airbag (same part number).<br />
•	Verified the clock spring is working.<br />
•	Had the wiring professionally checked – no faults.<br />
•	Even tried using a resistor to simulate the airbag – same fault returned.</p>
<p dir="auto">The conclusion was: maybe the SRS ECU is faulty.</p>
<p dir="auto">⸻</p>
<p dir="auto">What I Tried Using VDASH:</p>
<p dir="auto">I subscribed to VDASH and requested the PIN originally to disable the Trailer Module (TRM) — but that also failed, even after unlocking with the correct PIN.</p>
<p dir="auto">Then I moved on to SRS configuration using VDASH:</p>
<p dir="auto">Equipment:<br />
•	Started with VOE Ethernet OBD, but it kept failing on key features.<br />
•	Upgraded to the Super J2534 cable (officially listed as compatible by VDASH).</p>
<p dir="auto">⸻</p>
<p dir="auto">SRS ECU Configuration Attempts:<br />
1.	Original SRS ECU, Paid for ECU Configuration<br />
•	VDASH showed “configuration successful” after ~30 seconds.<br />
•	But nothing changed. Fault code B00012A still there.<br />
2.	Donor SRS ECU (same part number)<br />
•	Paid again to configure this one.<br />
•	Same story: quick “successful” message but no change.<br />
•	Airbag light started flickering, and I got a VIN mismatch + same B00012A fault.</p>
<p dir="auto">I then reinstalled the original ECU, defeated, with no improvement.</p>
<p dir="auto">⸻</p>
<p dir="auto">Other Ongoing Problems:<br />
•	I cannot restore CEM to original values — VDASH always gives a “can’t read ECM data” error.<br />
•	I cannot clone ECUs — dropdown is empty even when all hardware is connected and the car is powered properly.<br />
•	VDASH says “successful,” but it doesn’t seem to actually write or change anything.<br />
•	Feels like I’m stuck in a loop with no real progress, despite the “green lights” and power all reading correctly.</p>
<p dir="auto">⸻</p>
<p dir="auto">My Questions:<br />
•	Has anyone fixed B00012A through VDASH or another method?<br />
•	Could the SRS ECU store airbag serial data, and mismatched values are causing this?<br />
•	Has anyone else gotten VIN mismatch errors when swapping a “compatible” SRS ECU?<br />
•	Why would configuration complete in seconds without any visible effect?<br />
•	What does the “can’t read ECM data” error actually mean? Could it block other functions?<br />
•	Any recommended Volvo diagnostic tools that actually work?</p>
<p dir="auto">⸻</p>
<p dir="auto">If anyone’s been through something similar or can give any guidance, I’d truly appreciate it. I’ve already invested a fortune and a lot of time — I just want to get the car working safely again.</p>
<p dir="auto">Thanks in advance,<br />
Marwan</p>
]]></description><link>https://forum.d5t5.com/topic/129/help-needed-srs-airbag-fault-b00012a-still-not-fixed-after-replacing-ecu-and-using-vdash</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 02:56:11 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/129.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Jun 2025 15:19:02 GMT</pubDate><ttl>60</ttl></channel></rss>
