<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[immobilizer off]]></title><description><![CDATA[<p dir="auto">Hi<br />
Have sponserd account,how to go to make immobilizer off.<br />
have contact with car via duice and i can read car with vdash.<br />
Step by step please from cost to how to,I am new with Vdash.</p>
]]></description><link>https://forum.d5t5.com/topic/171/immobilizer-off</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 02:46:43 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/171.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Aug 2025 07:18:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to immobilizer off on Fri, 15 Aug 2025 13:38:09 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much, will do as you say.</p>
]]></description><link>https://forum.d5t5.com/post/394</link><guid isPermaLink="true">https://forum.d5t5.com/post/394</guid><dc:creator><![CDATA[Mir 21]]></dc:creator><pubDate>Fri, 15 Aug 2025 13:38:09 GMT</pubDate></item><item><title><![CDATA[Reply to immobilizer off on Thu, 14 Aug 2025 13:41:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/656">@Mir-21</a> both voltages should show something around 12V when the ignition is on. Check all fuses and also the connectors and grounds of the ECM, CEM, SRS. Maybe something became lose in the event of the crash.</p>
]]></description><link>https://forum.d5t5.com/post/393</link><guid isPermaLink="true">https://forum.d5t5.com/post/393</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Thu, 14 Aug 2025 13:41:44 GMT</pubDate></item><item><title><![CDATA[Reply to immobilizer off on Thu, 14 Aug 2025 10:44:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi, In Vida go to the “information” heading at the top, then “Product specification”, the “Specifications Other” then any module you care to expand has “Description of Parameters”. There you can see the parameter ranges and define if the values you are receiving are within, or out of range.</p>
]]></description><link>https://forum.d5t5.com/post/392</link><guid isPermaLink="true">https://forum.d5t5.com/post/392</guid><dc:creator><![CDATA[joroartcorp]]></dc:creator><pubDate>Thu, 14 Aug 2025 10:44:44 GMT</pubDate></item><item><title><![CDATA[Reply to immobilizer off on Tue, 12 Aug 2025 16:58:43 GMT]]></title><description><![CDATA[<p dir="auto">Thank you T5 T6 Schnappi.<br />
In vida I get all parameter ok exept 2 which I think its the problem,<br />
ECM -control module voltage ........................................0.11 V<br />
ECM-battery voltage......................................................0.06 V<br />
are these normal?or its because of immobilizer on?<br />
thank you again</p>
]]></description><link>https://forum.d5t5.com/post/391</link><guid isPermaLink="true">https://forum.d5t5.com/post/391</guid><dc:creator><![CDATA[Mir 21]]></dc:creator><pubDate>Tue, 12 Aug 2025 16:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to immobilizer off on Sun, 10 Aug 2025 15:45:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/656">@Mir-21</a> there is no way to disable or circumvent the immobilizer with vdash.</p>
<p dir="auto">If all keyfobs for the car are missing, you can decode the CEM pin and IMMO pin and simply add new fobs to the car. (except keyless ones).</p>
<p dir="auto">If the existing fobs don't work anymore, you need to replace the immobilizer antenna. Here <a href="https://parts.volvocarsofmarietta.com/a/Volvo_2010_V70-32l-6-cylinder/_51513_5697318/Ignition-switch/GR-366172.html?assemblySearchGuid=98B8BC63-0131-492B-97AC-D9261C5D2F42" rel="nofollow ugc">https://parts.volvocarsofmarietta.com/a/Volvo_2010_V70-32l-6-cylinder/_51513_5697318/Ignition-switch/GR-366172.html?assemblySearchGuid=98B8BC63-0131-492B-97AC-D9261C5D2F42</a> you can find the part numbers.</p>
<p dir="auto">If your car was involved in an accident, your car is in“ crash mode“ and won't start. In this case you have to replace all airbags that were deployed, and than you can use vdash to get your car back to live.</p>
]]></description><link>https://forum.d5t5.com/post/387</link><guid isPermaLink="true">https://forum.d5t5.com/post/387</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Sun, 10 Aug 2025 15:45:47 GMT</pubDate></item></channel></rss>
