<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V60 DIM&#x2F;climate control panel problem]]></title><description><![CDATA[<p dir="auto">Volvo V60 2013 (P3 platform)<br />
Engine: D4 D4162T<br />
<img src="https://forum.d5t5.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2757.png?v=3s5kcb9o796" class="not-responsive emoji emoji-android emoji--exclamation" style="height:23px;width:auto;vertical-align:middle" title=":exclamation:" alt="❗" /> Problem description<br />
After removing and reinstalling the DIM (doesn't change) while the battery was still connected, the climate control completely stopped working.<br />
<img src="https://forum.d5t5.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f50d.png?v=3s5kcb9o796" class="not-responsive emoji emoji-android emoji--mag" style="height:23px;width:auto;vertical-align:middle" title=":mag:" alt="🔍" /> Symptoms<br />
Climate control panel is dead (no response)<br />
No backlight on climate buttons<br />
Climate buttons and center console buttons do not respond<br />
Engine starts and runs normally<br />
DIM powers on and displays information normally<br />
<img src="https://forum.d5t5.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f4df.png?v=3s5kcb9o796" class="not-responsive emoji emoji-android emoji--pager" style="height:23px;width:auto;vertical-align:middle" title=":pager:" alt="📟" /> Diagnostics / DTCs<br />
Using VIDA / VDash / diagnostics:<br />
CCM is not active / not responding<br />
CEM-U016400 – Lost communication with Climate Control Module (CCM)<br />
CVM-U042468 – Invalid data received from HVAC control module<br />
DIM-U300045 – Control module internal failure / configuration issue<br />
CAN communication is present, but LIN comfort network does not wake up.<br />
🧪 What has already been checked<br />
All related fuses checked<br />
Battery reset / sleep procedures done<br />
CCM, DIM and other modules are physically connected correctly<br />
No signs of hardware damage<br />
Main goal is to restore climate control<br />
Any experience, confirmation or technical insight would be greatly appreciated.</p>
]]></description><link>https://forum.d5t5.com/topic/255/v60-dim-climate-control-panel-problem</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 23:53:06 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/255.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Jan 2026 20:30:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to V60 DIM&#x2F;climate control panel problem on Sun, 11 Jan 2026 21:08:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/963">@Oleksandr1540</a> DIM-U300045 is the result of milage manipulation. Vdash should provide a software reload to fix this. Just connect your car to vdash and click on the DIM. There should be an option to perform a software update/reload. Use a Mongoose JLR or Super J2534 adapter for this. Don't do this if your adapter is a Vxdiag/Vxnano, or you will brick your car.</p>
]]></description><link>https://forum.d5t5.com/post/693</link><guid isPermaLink="true">https://forum.d5t5.com/post/693</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Sun, 11 Jan 2026 21:08:57 GMT</pubDate></item><item><title><![CDATA[Reply to V60 DIM&#x2F;climate control panel problem on Sun, 11 Jan 2026 13:06:07 GMT]]></title><description><![CDATA[<p dir="auto">The issue turned out to be a fuse and a poor electrical contact. After fixing that, the main problem was resolved.<br />
However, I would really appreciate it if someone could advise how to properly fix the DIM issue (diagnostics, repair, or software-related solutions).</p>
]]></description><link>https://forum.d5t5.com/post/692</link><guid isPermaLink="true">https://forum.d5t5.com/post/692</guid><dc:creator><![CDATA[Oleksandr1540]]></dc:creator><pubDate>Sun, 11 Jan 2026 13:06:07 GMT</pubDate></item></channel></rss>
