<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ECM-1000, ECM-135F, ECM-1600 V50]]></title><description><![CDATA[<p dir="auto">Getting a few codes on my D5 V50, 2008.<br />
The codes are stated in the topic.</p>
<p dir="auto">I have changed MAF several times, as well as MAP sensor and also the TCV on the turbo. I get the code ECM-1600 (MAP) first (triggered first), then the ECM-135F for the MAF, then the ECM-1000.</p>
<p dir="auto">No matter how many times I change the parts, the same codes come up.<br />
I have tried doing some research on the ECM-1000 and seems like the issue is internally in the ECM itself. I will try to clone the ECM to see if I can copy to an external ECM, unless someone has any tips?</p>
<p dir="auto">I have also tried to do a smoke test: revealing no leaks.</p>
]]></description><link>https://forum.d5t5.com/topic/262/ecm-1000-ecm-135f-ecm-1600-v50</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 00:39:00 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/262.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Jan 2026 20:03:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ECM-1000, ECM-135F, ECM-1600 V50 on Tue, 27 Jan 2026 23:17:45 GMT]]></title><description><![CDATA[<p dir="auto">The combination of all 3 codes indicate a problem with the map sensor.</p>
]]></description><link>https://forum.d5t5.com/post/718</link><guid isPermaLink="true">https://forum.d5t5.com/post/718</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Tue, 27 Jan 2026 23:17:45 GMT</pubDate></item><item><title><![CDATA[Reply to ECM-1000, ECM-135F, ECM-1600 V50 on Tue, 27 Jan 2026 22:49:04 GMT]]></title><description><![CDATA[<p dir="auto">Check your swirl flaps and clean the map sensor located at the intercooler.</p>
]]></description><link>https://forum.d5t5.com/post/717</link><guid isPermaLink="true">https://forum.d5t5.com/post/717</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Tue, 27 Jan 2026 22:49:04 GMT</pubDate></item></channel></rss>
