<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Volvo S60 2014]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">I have this Volvo S60 D4 ( 2014 ), and when I tested it with DiCE, i have this error:</p>
<p dir="auto">CEM-U030141  - Software incompatibility with ECM/PCM - Sistem internal failures - General CheckSum Failure.</p>
<p dir="auto">any ideea guys, how can it be fixed?</p>
<p dir="auto">10x a lot  !</p>
]]></description><link>https://forum.d5t5.com/topic/266/volvo-s60-2014</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 00:47:30 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/266.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Feb 2026 12:24:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Volvo S60 2014 on Thu, 05 Mar 2026 15:23:44 GMT]]></title><description><![CDATA[<p dir="auto">NO, no DTC's that is why I was presuming that something is wrong:)</p>
]]></description><link>https://forum.d5t5.com/post/812</link><guid isPermaLink="true">https://forum.d5t5.com/post/812</guid><dc:creator><![CDATA[sizan]]></dc:creator><pubDate>Thu, 05 Mar 2026 15:23:44 GMT</pubDate></item><item><title><![CDATA[Reply to Volvo S60 2014 on Wed, 11 Feb 2026 20:35:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/923">@sizan</a> CEM/ ECM error and CCM problems are not related to each other. You can try to perform LIN discovery and recalibrate damper motors afterwards. Are there really no DTCs in the CCM? Incorrect step values should produce a DTC.</p>
]]></description><link>https://forum.d5t5.com/post/758</link><guid isPermaLink="true">https://forum.d5t5.com/post/758</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Wed, 11 Feb 2026 20:35:39 GMT</pubDate></item><item><title><![CDATA[Reply to Volvo S60 2014 on Wed, 11 Feb 2026 15:35:13 GMT]]></title><description><![CDATA[<p dir="auto">no opinions?</p>
]]></description><link>https://forum.d5t5.com/post/756</link><guid isPermaLink="true">https://forum.d5t5.com/post/756</guid><dc:creator><![CDATA[sizan]]></dc:creator><pubDate>Wed, 11 Feb 2026 15:35:13 GMT</pubDate></item><item><title><![CDATA[Reply to Volvo S60 2014 on Wed, 04 Feb 2026 08:54:40 GMT]]></title><description><![CDATA[<p dir="auto">No, the DPF is not removed ( checked ) and the EGR and the cooler we're changed at a volvo dealer in Sweden as the volvo dealer showed me on the computer and i have the operations mentioned on the car book.</p>
<p dir="auto">interesting info about the blanking plate for the egr, i will check <img src="https://forum.d5t5.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=3s5kcb9o796" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">One more question : it seems that i have some problems with the fact that the air is not venting corect and as before. So, no error about the CCM whatsoever, but if I try to calibrate the damper motors, looks like it is done all ok, but the values are all wrong.  ( ex : recirculation motor  preset range 810 steps, actual range 3075 steps ) and so.</p>
<p dir="auto">Is it possibile that vida will not show the ccm errors cause that ECM issue? maybe I am missing some other errors about the car..</p>
]]></description><link>https://forum.d5t5.com/post/742</link><guid isPermaLink="true">https://forum.d5t5.com/post/742</guid><dc:creator><![CDATA[sizan]]></dc:creator><pubDate>Wed, 04 Feb 2026 08:54:40 GMT</pubDate></item><item><title><![CDATA[Reply to Volvo S60 2014 on Tue, 03 Feb 2026 22:20:48 GMT]]></title><description><![CDATA[<p dir="auto">This indicates that your car has a tuning or modified software installed on the ECM. Most probably a so called EGR delete as your car is a diesel. Some info here: <a href="https://d5t5.com/article/zname-dtc-po-uprave-vykonu" rel="nofollow ugc">https://d5t5.com/article/zname-dtc-po-uprave-vykonu</a> You can visit an official volvo dealer and ask for a software reload for the ECM with VIDA to revert to the original software, but I can't recommend this, as you will have lots of other problems afterwards,because there are most probably have been done some more modifications to your car. For example a blanking plate for the EGR, or maybe even the DPF is removed.</p>
]]></description><link>https://forum.d5t5.com/post/741</link><guid isPermaLink="true">https://forum.d5t5.com/post/741</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Tue, 03 Feb 2026 22:20:48 GMT</pubDate></item></channel></rss>
