<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VDASH error codes following headlight replacement]]></title><description><![CDATA[<p dir="auto">Hello, following a frontal right side collision and replacement of the headlight and HCR unit with used items, there is a displayed error message "Dipped beam malfunction" when the lights are switched on. All lights work correctly<br />
Connecting VDASH displays the following error codes:<br />
CEM-B14C281 Head Lamp Input. Bus signal/Message failures. Invalid serial data received.<br />
HCMR-B15A771 Headlamp control module Fan Diag spin speed Error (stall). Mechanical failures. Actuator stuck.<br />
HCMR-B15215 Headlamp control module High driver side channel 1. General electrical failures. Circuit short to battery or open.<br />
Erasing codes does not clear these codes.<br />
I'm unclear if these codes are the result of the collision, if so why do they not clear?<br />
I have also been told that a new, not used, HCM should be purchased as it needs to be programmed in VIDA.<br />
I would like to programme the used HCM, is this possible? If so, how,  as the original unit was broken so I cannot clone from the original.<br />
Please can someone outline the next steps I should take to resolve this problem?<br />
Many thanks<br />
Microbe</p>
]]></description><link>https://forum.d5t5.com/topic/27/vdash-error-codes-following-headlight-replacement</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 16:31:32 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/27.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jan 2025 17:18:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VDASH error codes following headlight replacement on Sun, 26 Jan 2025 01:11:47 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem on my xc90 mk2 2018 - i replaced the left headlight with a used one and fitted the original light module to it but the daytime running light / indicator led module (led ballast) was physically broken - when i fit a brand new uncoded module i get similar error codes…. The indicator flashes normally but the dash indicator blinks fast as if a bulb is blown and the daytime running light doesnt work in that light - can this be coded to the car using vdash ?</p>
]]></description><link>https://forum.d5t5.com/post/56</link><guid isPermaLink="true">https://forum.d5t5.com/post/56</guid><dc:creator><![CDATA[tim2985]]></dc:creator><pubDate>Sun, 26 Jan 2025 01:11:47 GMT</pubDate></item></channel></rss>
