<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changed configuration, now VDASH and VIDA report different values.  Is this normal?]]></title><description><![CDATA[<p dir="auto">Hi.  2010 XC60 T6 USA.  I decoded my pin and updated the configuration, modifying the "tyre circumference" parameter from 2250mm to 2395mm.  After making the change successfully in VDASH, I reloaded my configuration in VITA just to check it, and VIDA reports the tyre circumference as 2210mm.</p>
<p dir="auto">Do you all check your configuration changes against VITA, and do they match?  I'm concerned that VDASH has entered a value that is not compatible with my car and now I don't know which number to trust.</p>
]]></description><link>https://forum.d5t5.com/topic/309/changed-configuration-now-vdash-and-vida-report-different-values-is-this-normal</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 08:19:46 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/309.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 May 2026 23:39:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changed configuration, now VDASH and VIDA report different values.  Is this normal? on Sun, 03 May 2026 18:52:11 GMT]]></title><description><![CDATA[<p dir="auto">VIDA shows the factory configuration instead of the current one</p>
]]></description><link>https://forum.d5t5.com/post/1075</link><guid isPermaLink="true">https://forum.d5t5.com/post/1075</guid><dc:creator><![CDATA[Arnis2002]]></dc:creator><pubDate>Sun, 03 May 2026 18:52:11 GMT</pubDate></item></channel></rss>
