<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GUIDE: How to obtain the CEM pin on any PreFL P2 (S60I, S80I, V70II, XC70I, XC90I MY 1999-2004) in around 60 seconds]]></title><description><![CDATA[<p dir="auto">WARNING! The software shown here is still experimental. Using any other functions/options than the ones shown in this guide can and will brick your car as they are not working (yet) or are unreliable to use. You will get zero support from anybody if anything goes wrong.</p>
<p dir="auto">Please read the whole guide before you start.</p>
<p dir="auto">This Guide should work for all brick shaped CEMs (CEM-B) with the following part numbers:</p>
<p dir="auto">8602436<br />
8645171<br />
8645200<br />
8645205<br />
8645716<br />
8645719<br />
8688434<br />
8688436<br />
8688513<br />
9452553<br />
9452596<br />
9469809<br />
9494336<br />
9494594<br />
30657629</p>
<p dir="auto">Prerequisites:<br />
Laptop with Windows 10/11<br />
Original DICE / Full Chip DICE Clone or Mongoose Pro/Super J2534; other adapters do not work for this<br />
Optional: Battery charger/tender if your battery can’t maintain a stable voltage of 12,5V+ for around 10 minutes with Ignition on</p>
<p dir="auto">-Download OpenMoose Renatus from here <a href="http://www.openmoose.net" rel="nofollow ugc">http://www.openmoose.net</a></p>
<p dir="auto">-Unpack the archive to a folder of your choice and start the OpenMoose .exe<br />
-Click on “Settings”(1.)<br />
-Select your adapter type “DICE” or “Mongoose”, and the Baud rate “125/250 (-2004)” (2.)<br />
-Connect the adapter to your car and turn the ignition to Pos. II (Ignition on/Engine not running)<br />
-Click on CEM (4.)</p>
<p dir="auto"><img src="/assets/uploads/files/1778231008475-om1.png" alt="OM1.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">-Click on “Connect” (5.) and wait until your vehicle type and model year is shown in the top right corner.<br />
-Click on “Fast recover PIN”(6.)</p>
<p dir="auto"><img src="/assets/uploads/files/1778231051809-om2.png" alt="OM2.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">-It should take 60-180 seconds to retrieve the PIN, depending on the adapter you are using<br />
-If a PIN is found, write it down or make a screenshot<br />
<img src="/assets/uploads/files/1778231064081-om3.png" alt="OM3.PNG" class=" img-fluid img-markdown" /><br />
-DO NOT USE THE “Test PIN” OPTION!!!<br />
-Click on “Disconnect” and close OpenMoose<br />
-Ignition Off</p>
<p dir="auto">Use this form <a href="https://d5t5.com/helpdesk/create/ticket/pin" rel="nofollow ugc">https://d5t5.com/helpdesk/create/ticket/pin</a> to add your PIN to the Vdash database</p>
<p dir="auto">Or do it from within Vdash:<br />
-Switch the Ignition to Pos.II<br />
-Start Vdash and connect to your car<br />
-Once all modules have been loaded, click on “Security”</p>
<p dir="auto"><img src="/assets/uploads/files/1778231094085-v1.png" alt="V1.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">-Click on “PIN, IMMO Codes”</p>
<p dir="auto"><img src="/assets/uploads/files/1778231103112-v2.png" alt="V2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">-Click on “Add PIN” (1.) and enter the PIN without spaces<br />
-Click on “Continue” (2.) and wait a moment</p>
<p dir="auto"><img src="/assets/uploads/files/1778231115519-v3.png" alt="V3.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">-Close all Tabs in Vdash, wait a short moment for Vdash database to update, and reconnect to your car</p>
<p dir="auto">-Check if your PIN was successfully added in Vdash<br />
-Go to “Security”/”Manage PINs” (again), and see if your PIN is listed<br />
<img src="/assets/uploads/files/1778231128683-v4.png" alt="V4.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">-Done</p>
<p dir="auto">If no PIN is found, your only option is bench reading. The teensy method <a href="https://github.com/vtl/volvo-cem-cracker/tree/cem-b" rel="nofollow ugc">https://github.com/vtl/volvo-cem-cracker/tree/cem-b</a> will also not work as it uses the same approach.</p>
]]></description><link>https://forum.d5t5.com/topic/311/guide-how-to-obtain-the-cem-pin-on-any-prefl-p2-s60i-s80i-v70ii-xc70i-xc90i-my-1999-2004-in-around-60-seconds</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 11:46:16 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/311.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2026 09:13:30 GMT</pubDate><ttl>60</ttl></channel></rss>
