<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t read TDC polestar 2 2023]]></title><description><![CDATA[<p dir="auto">Hi ! I installed vdash on my laptop yesterday, my car is detected but when I click Read TDC or Clear TDC I get a pop up window with Command Not Found in it. No TDC shows up. I currently have the front bumper off so there should be some TDC to show.</p>
<p dir="auto">I use a VOE cable,and I have to put the car in drive (D) in order for vdash to see it</p>
]]></description><link>https://forum.d5t5.com/topic/322/can-t-read-tdc-polestar-2-2023</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 21:01:10 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/322.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 May 2026 14:08:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 17:39:59 GMT]]></title><description><![CDATA[<p dir="auto">In this case, I should go with Vida to do all the configuration, that way I would be safe</p>
]]></description><link>https://forum.d5t5.com/post/1193</link><guid isPermaLink="true">https://forum.d5t5.com/post/1193</guid><dc:creator><![CDATA[bastienlaf]]></dc:creator><pubDate>Mon, 25 May 2026 17:39:59 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 15:59:34 GMT]]></title><description><![CDATA[<p dir="auto">Oh, thanks for the information. That means, if I ever sell the car I would need to revert all changes before selling it (which would remove headlight and blind spot sensor configuration) ?</p>
]]></description><link>https://forum.d5t5.com/post/1192</link><guid isPermaLink="true">https://forum.d5t5.com/post/1192</guid><dc:creator><![CDATA[bastienlaf]]></dc:creator><pubDate>Mon, 25 May 2026 15:59:34 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 15:30:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1302">@bastienlaf</a> Orbit offers the pin retrieval as a paid service and actually shows you all pins you paid for. Vdash can't crack/obtain any of the pins you need. But even it would be possible through Vdash, you wouldn't get to see the pins. The rest of the functionalities are basically the same for both softwares.<br />
And if you want to visit a volvo dealer, you need to revert all changes done with Vdash or Orbit, or your car will be blacklisted for all software updates. <a href="https://d5t5.com/article/vida_software%20_download_failed_car_blocked" rel="nofollow ugc">https://d5t5.com/article/vida_software _download_failed_car_blocked</a></p>
]]></description><link>https://forum.d5t5.com/post/1191</link><guid isPermaLink="true">https://forum.d5t5.com/post/1191</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Mon, 25 May 2026 15:30:46 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:45:36 GMT]]></title><description><![CDATA[<p dir="auto">I need to configure my headlight and blindspot sensor so I will need the PIN, just debating wether I buy Vdash or OrBit</p>
]]></description><link>https://forum.d5t5.com/post/1190</link><guid isPermaLink="true">https://forum.d5t5.com/post/1190</guid><dc:creator><![CDATA[bastienlaf]]></dc:creator><pubDate>Mon, 25 May 2026 14:45:36 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:42:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1302">@bastienlaf</a> P* are a little bit out of my experience, so I can't tell what might be the problem here. But I think it's either your computer that has problems with using 2 network connections simultaneously. One to your car and one to Internet. Or the Vdash servers need a little kick in the butt.<br />
You can also try this software <a href="https://vtool.info/" rel="nofollow ugc">https://vtool.info/</a> but you will still need the VGM pin to delete codes.</p>
]]></description><link>https://forum.d5t5.com/post/1189</link><guid isPermaLink="true">https://forum.d5t5.com/post/1189</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Mon, 25 May 2026 14:42:16 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:31:32 GMT]]></title><description><![CDATA[<p dir="auto">Yes, when I click connect it opens the vehicle detect tab, in this I can click READ TCD, but it doesn't show tdc just the error code.<br />
I was sitting no the driver seat and had the car in D, not it N maybe that's my issue. Also driver door was open</p>
]]></description><link>https://forum.d5t5.com/post/1188</link><guid isPermaLink="true">https://forum.d5t5.com/post/1188</guid><dc:creator><![CDATA[bastienlaf]]></dc:creator><pubDate>Mon, 25 May 2026 14:31:32 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:29:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1302">@bastienlaf</a> did you click on connect in the top left corner?</p>
]]></description><link>https://forum.d5t5.com/post/1187</link><guid isPermaLink="true">https://forum.d5t5.com/post/1187</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Mon, 25 May 2026 14:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:28:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1302">@bastienlaf</a> You also need to put the car in D and then in N to read codes. And you have to sit on the drivers seat all the time. Putting the car in P or leaving the seat will end the communication with the car.</p>
]]></description><link>https://forum.d5t5.com/post/1186</link><guid isPermaLink="true">https://forum.d5t5.com/post/1186</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Mon, 25 May 2026 14:28:16 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:26:31 GMT]]></title><description><![CDATA[<p dir="auto">I don't see any module in the page, I only see that it's connected to the car, but it shows no information other than the VIN<br />
I don't have 3rd party antivirus or security, just basic Microsoft stuff.</p>
]]></description><link>https://forum.d5t5.com/post/1185</link><guid isPermaLink="true">https://forum.d5t5.com/post/1185</guid><dc:creator><![CDATA[bastienlaf]]></dc:creator><pubDate>Mon, 25 May 2026 14:26:31 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:21:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1302">@bastienlaf</a> do you have any 3rd party antivirus, security, firewall software installed?</p>
]]></description><link>https://forum.d5t5.com/post/1184</link><guid isPermaLink="true">https://forum.d5t5.com/post/1184</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Mon, 25 May 2026 14:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:20:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1302">@bastienlaf</a> I can't tell you why Vdash doesn't read any codes, but to delete them, you will need the VGM pin for your car. This pin can only be obtained by installing a software update/reload via the official VIDA and monitoring the traffic between the car and VIDA while this happens. Do you see all modules after clicking connect in Vdash? If yes, in which colours?</p>
]]></description><link>https://forum.d5t5.com/post/1183</link><guid isPermaLink="true">https://forum.d5t5.com/post/1183</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Mon, 25 May 2026 14:20:00 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t read TDC polestar 2 2023 on Mon, 25 May 2026 14:15:35 GMT]]></title><description><![CDATA[<p dir="auto">Note, in the vehicle detect page I also don't have the mileage or service information</p>
]]></description><link>https://forum.d5t5.com/post/1182</link><guid isPermaLink="true">https://forum.d5t5.com/post/1182</guid><dc:creator><![CDATA[bastienlaf]]></dc:creator><pubDate>Mon, 25 May 2026 14:15:35 GMT</pubDate></item></channel></rss>
