<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ACC Retrofit]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">After installing the FSM and FLR on my V40, driving for a while to make sure everything is working as it should, I'm now starting to go further with the ACC retrofit.</p>
<p dir="auto">New brakebooster and BCM are already in my posession, yet still have to start mounting them. I'm aware that on the V40 this project isn't as straight forward as it is on other P3 models, because of the BCM and data on the EEPROM that needs to be transferred.</p>
<p dir="auto">Do I really need to swap the EEPROM from my current one to the donor BCM, or read and write the data over between the 2 units, or will the BCM clone function inside VDASH do the same without needing to opening up the BCM?</p>
]]></description><link>https://forum.d5t5.com/topic/327/acc-retrofit</link><generator>RSS for Node</generator><lastBuildDate>Sun, 31 May 2026 17:49:58 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/327.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 May 2026 15:35:32 GMT</pubDate><ttl>60</ttl></channel></rss>
