<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Volvo XC40 2019 (P5 platform) – Parking brake issue after VDASH initialization check]]></title><description><![CDATA[<p dir="auto">I connected VDASH to my 2019 Volvo XC40 and ran the VDDM "Initialization Check" function. The procedure completed successfully and reported "OK".</p>
<p dir="auto">Immediately afterwards, the parking brake behavior changed:</p>
<p dir="auto">The electronic parking brake can still be applied normally using the center console switch.<br />
The parking brake will NOT release using the center console switch.<br />
The parking brake CAN be released through VDASH ("Release parking brake" function).<br />
The vehicle drives normally once the brake is released through VDASH.<br />
No brake warnings are displayed on the dashboard.<br />
No ABS or BCM fault codes are present.</p>
<p dir="auto">The only relevant fault code that appeared is:</p>
<p dir="auto">VDDM-B111153<br />
"Electric park brake enable. System Programming Failures. Deactivated."</p>
<p dir="auto">Service mode was never activated. "Exit service mode" returns an error because service mode is not active. The issue started immediately after running the Initialization Check.</p>
<p dir="auto">Has anyone encountered this before or knows how to restore normal parking brake release operation after a VDDM initialization check?</p>
]]></description><link>https://forum.d5t5.com/topic/328/volvo-xc40-2019-p5-platform-parking-brake-issue-after-vdash-initialization-check</link><generator>RSS for Node</generator><lastBuildDate>Mon, 01 Jun 2026 21:15:06 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/328.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Jun 2026 19:58:41 GMT</pubDate><ttl>60</ttl></channel></rss>
