<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HCMR module cloning cost + procedure — Volvo XC60 II (SPA)]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I have a 2018+ Volvo XC60 II (SPA platform) with fault codes HCMR-B15AA13 (signal/circuit fault), CEM-B14C281 (invalid serial data from headlamp module), and ASDM-U2C6992 (invalid data received) — right headlamp flickering very dim and fast.<br />
I have sourced a used HCMR with the following data (read from my original module before swapping):</p>
<p dir="auto">HW: 31427777<br />
SW1: 32365262<br />
SW2: 32365264<br />
SW3: 32133951<br />
Serial: 60591409</p>
<p dir="auto">I connect via an Ethernet-to-OBD2 (ENET) cable, which works fine for diagnostics.<br />
Questions:</p>
<p dir="auto">Can VDASH clone/configure a used HCMR to the correct side (right) on this platform, and is CEM PIN decoding required for this specific operation?<br />
Will my ENET cable work for the full HCM clone/programming procedure, or is this one of the operations that specifically requires DiCE/SUPER J2534?<br />
What is the approximate cost (in the cart) for HCM module cloning/side-configuration on a SPA platform vehicle?<br />
Is there anything specific I should check on the used module (part number/HW revision) before pairing it, to confirm Active Bending Light compatibility?</p>
<p dir="auto">Thanks in advance for any guidance.</p>
<p dir="auto">Je kunt dit posten in het algemene VDASH-forum of in een meer specifiek subforum als er een voor SPA-platforms of HCM-vragen bestaat — check de forumstructuur even voordat je plaatst. Wil je dat ik ook help met een Tsjechisch/Engels begeleidend berichtje voor de directe D5T5-supportchat, voor het geval het forum traag reageert?</p>
]]></description><link>https://forum.d5t5.com/topic/343/hcmr-module-cloning-cost-procedure-volvo-xc60-ii-spa</link><generator>RSS for Node</generator><lastBuildDate>Fri, 26 Jun 2026 19:26:41 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/343.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jun 2026 16:30:18 GMT</pubDate><ttl>60</ttl></channel></rss>
