<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Another DIM-U300045 fault]]></title><description><![CDATA[<p dir="auto">Been going through the fault codes on my P3 XC70, and this is the final code I have to fix. It looks like someone may have been playing around with the milage on the car. I've read the post below and not 100% sure how to clear the code as it look like the module needs to be flashed back to the original firmware but not sure where to get that. Can someone help with this please. I deleted the old post as I put the wrong vin in and added ECU units.</p>
<p dir="auto">Just one other quick question, is it possible to code /configure the car so when you switch the engine off the parking brake is applied. I'm used to Audi's and this is enabled by default so just wondering if it's an option on the volvo.</p>
]]></description><link>https://forum.d5t5.com/topic/35/another-dim-u300045-fault</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 09:05:50 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/35.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Jan 2025 22:21:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Another DIM-U300045 fault on Mon, 17 Feb 2025 10:40:54 GMT]]></title><description><![CDATA[<p dir="auto">Plugged in vdash yesterday and stated a firmware was available for my cluster. Flashed the file today and the error code has gone. Milage changed from 271 109 km to 271 085 km why would some alter the milage for only 24km?</p>
]]></description><link>https://forum.d5t5.com/post/98</link><guid isPermaLink="true">https://forum.d5t5.com/post/98</guid><dc:creator><![CDATA[LAMAII]]></dc:creator><pubDate>Mon, 17 Feb 2025 10:40:54 GMT</pubDate></item><item><title><![CDATA[Reply to Another DIM-U300045 fault on Thu, 06 Feb 2025 11:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/155">@Lapinautodiagnostiikka</a> Just waiting D5T5 to get back to me on the file I uploaded</p>
]]></description><link>https://forum.d5t5.com/post/77</link><guid isPermaLink="true">https://forum.d5t5.com/post/77</guid><dc:creator><![CDATA[LAMAII]]></dc:creator><pubDate>Thu, 06 Feb 2025 11:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to Another DIM-U300045 fault on Thu, 06 Feb 2025 10:09:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/142">@LAMAII</a> Did that work?</p>
]]></description><link>https://forum.d5t5.com/post/75</link><guid isPermaLink="true">https://forum.d5t5.com/post/75</guid><dc:creator><![CDATA[Lapinautodiagnostiikka]]></dc:creator><pubDate>Thu, 06 Feb 2025 10:09:12 GMT</pubDate></item><item><title><![CDATA[Reply to Another DIM-U300045 fault on Wed, 05 Feb 2025 12:07:24 GMT]]></title><description><![CDATA[<p dir="auto">Made a clone of the ECU, but cancelled the write.</p>
]]></description><link>https://forum.d5t5.com/post/70</link><guid isPermaLink="true">https://forum.d5t5.com/post/70</guid><dc:creator><![CDATA[LAMAII]]></dc:creator><pubDate>Wed, 05 Feb 2025 12:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to Another DIM-U300045 fault on Tue, 04 Feb 2025 19:39:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I'll get that done tomorrow.</p>
]]></description><link>https://forum.d5t5.com/post/68</link><guid isPermaLink="true">https://forum.d5t5.com/post/68</guid><dc:creator><![CDATA[LAMAII]]></dc:creator><pubDate>Tue, 04 Feb 2025 19:39:35 GMT</pubDate></item><item><title><![CDATA[Reply to Another DIM-U300045 fault on Mon, 03 Feb 2025 12:16:05 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">please start the clone operation of the DIM in VDASH (read takes a minute or two), cancel it before it asks you to write a copy. That way the server will have your non-original DIM content. Then I will check and may issue a corrected and proper version of your DIM, which will (likely) uncover the original mileage of your car.</p>
<p dir="auto">Regarding your second question: automatic parking brake has been introduced in SPA/CMA platform, and there's no (hidden) version of that in P3.</p>
]]></description><link>https://forum.d5t5.com/post/62</link><guid isPermaLink="true">https://forum.d5t5.com/post/62</guid><dc:creator><![CDATA[D5T5 ok2ucx]]></dc:creator><pubDate>Mon, 03 Feb 2025 12:16:05 GMT</pubDate></item></channel></rss>
