<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VCM no Ethernet signal]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm experiencing a problem with my VCM module, after install a ECM tune,i connected the VOE cable for some data logging and the Ethernet communication was lost . The tune was installed and the car is working fine but the Ethernet signal with VOE cable don't work, however i have connection with J2534 cable to Vdash. All the function of the VCM seems to be working fine (no problems with Gps location,wifi signal, VOC or volvo app).<br />
I've tested with 2 different VOE cable, 2 USB adapters and 2 laptops, also checked the fuse. Can anyone perhaps knows what's causing the problem and if there's any solution? Do i need to buy another VCM module?<br />
Thanks!</p>
]]></description><link>https://forum.d5t5.com/topic/355/vcm-no-ethernet-signal</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 13:54:07 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/355.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Jul 2026 01:12:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VCM no Ethernet signal on Sun, 12 Jul 2026 09:35:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/309">@Libelix</a> how did you install the tune? Flashing a tune doesn't do anything to the VCM.<br />
Using the VOE adapter requires a computer/laptop that is able to run 2 seperate network connections in parallel. One towards the car and another towards the internet. Most non-business/home user devices from HP, Dell, Acer and so on don't support that.</p>
]]></description><link>https://forum.d5t5.com/post/1393</link><guid isPermaLink="true">https://forum.d5t5.com/post/1393</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Sun, 12 Jul 2026 09:35:50 GMT</pubDate></item></channel></rss>
