<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ECM-6720 after egr+dpf off]]></title><description><![CDATA[<p dir="auto">Hello, greetings from Canada. I have a 2008 v50 2.4 d5 that I've blocked off egr and weight reduced the dpf. However after loading any iteration of the optimization for egr/dpf off I continue to get fault 6720 egr flow too high, and if I view live data egr valve movement is being commanded. If anyone has a solution to this I would greatly appreciate it as tuning options here are limited to basically just me.</p>
]]></description><link>https://forum.d5t5.com/topic/363/ecm-6720-after-egr-dpf-off</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 14:50:21 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/363.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Jul 2026 00:14:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ECM-6720 after egr+dpf off on Tue, 21 Jul 2026 01:40:38 GMT]]></title><description><![CDATA[<p dir="auto">Or maybe just disable it in the ECU?</p>
]]></description><link>https://forum.d5t5.com/post/1434</link><guid isPermaLink="true">https://forum.d5t5.com/post/1434</guid><dc:creator><![CDATA[Bartas222]]></dc:creator><pubDate>Tue, 21 Jul 2026 01:40:38 GMT</pubDate></item></channel></rss>
