<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V70III Oil indication in the DIM not updating. No Oil level Warnings.]]></title><description><![CDATA[<p dir="auto">Hi All.</p>
<p dir="auto">My 2016 Volvo V70 does not update the oil level in the DIM_module.</p>
<p dir="auto">My V70 has developed a thirst for Oil, and at its worst it only did 250 km while using 1L Castrol 0W20 V.</p>
<p dir="auto">I am currently working on a fix for this, and have improved oil burning to "only" 1L per 1250 km.</p>
<p dir="auto">I do have another problem, as my car doesn't give a notification when oil level is low. I can read the oil level via the ECU Diagnostics, and follow oil levels as I refill by the 0.01 mm, but the Oil level I can read in the DIM is always at top level even with no oil in the engine.</p>
<p dir="auto">Can I somehow reset the Oil level reading in the DIM so it will update the reading from the ECU?</p>
<p dir="auto">The car currently runs without any DTC's</p>
]]></description><link>https://forum.d5t5.com/topic/381/v70iii-oil-indication-in-the-dim-not-updating-no-oil-level-warnings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 31 Jul 2026 08:51:45 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/381.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jul 2026 06:04:29 GMT</pubDate><ttl>60</ttl></channel></rss>
