<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V60 B5254T12 2015, US, retrofit oil level sensor]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I need some advice on a problem I’m facing after retrofitting an OEM oil level sensor to my car.</p>
<p dir="auto">What has been done so far:<br />
Swapped the oil pan for a version with the sensor mounting hole.<br />
Installed and physically connected the oil level sensor to ECM. Wired the sensor directly into the Engine Control Module (ECM).<br />
Current status:Hardware-wise, everything seems correct.<br />
Diagnostics suggest that the ECM communicates with the sensor and detects its presence. However, the Driver Information Module (DIM / dashboard) continuously displays the message: "Oil level unavailable".<br />
My suspicion:I suspect the issue is software-related. The current software flash in the ECM might lack the active routine for this sensor, or the vehicle's central configuration (Car Configuration File - CCF) in the ECM needs to be updated to let the car know the sensor is now installed.</p>
<p dir="auto">My questions for the community:<br />
Has anyone successfully done this retrofit and can confirm if a software/configuration change is mandatory for the DIM to display the reading?Is it possible to reflash the ECM or alter the CCF configuration to activate this via VDASH?<br />
If yes, which tab/menu in VDASH should I look into, and what are the exact steps to follow (e.g., changing a specific configuration parameter vs. buying a dedicated software reload/tweak)?</p>
]]></description><link>https://forum.d5t5.com/topic/422/v60-b5254t12-2015-us-retrofit-oil-level-sensor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 01 Sep 2026 16:26:48 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/422.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Sep 2026 13:03:15 GMT</pubDate><ttl>60</ttl></channel></rss>
