<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Aisin TF-80SC unusual shifting problems]]></title><description><![CDATA[<p dir="auto">Hello, I'm having unusual issues with a MY2007 S80 equipped with a TF80SC, shifts absolutely perfect at high throttle/high rpm, no shudders (for the most part) and no slipping whatsoever, however the problems are as follows:<br />
Upshifting 3rd to 4th in Drive (at low/mid rpm, ~40kmh shift point) kills acceleration, rpm drops then picks back up again - I can only imagine it erroneously applies the torque convertor clutch at low speed then disengages it, and later engages it properly at the intended speed (~50 kmh), if in manual mode waiting for the clutch to apply fully in 3rd gear then upshifting there's no issue, or just flogging it where the clutch doesn't really apply.<br />
Downshifting from 3rd to 2nd creates a horrible jerking/shuddering, worse when cold, happens mostly when decelerating with medium/lower braking, does it when manually downshifting, again presumably the converter clutch is an issue considering how if it doesn't apply in the first place the downshift is unnoticeable.</p>
<p dir="auto">I've had the car for about 4 months in which time it hasn't gotten worse or improved, previous owner said he changed the fluid AND did an adaptation, which leads to my question, is this potentially from a poor quality adaptation (like if the instructions weren't followed or was done in bad traffic) or some other software issue, I know of how picky these boxes can be with fluid and various valve body hijinks but it doesn't seem like it in this case, i can post the software ID of the TCM if needed or other information, since this one singular post is probably way too long already. Many thanks.</p>
]]></description><link>https://forum.d5t5.com/topic/440/aisin-tf-80sc-unusual-shifting-problems</link><generator>RSS for Node</generator><lastBuildDate>Sat, 10 Oct 2026 04:31:41 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/440.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Oct 2026 15:33:44 GMT</pubDate><ttl>60</ttl></channel></rss>
