<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to retrieve IMMO key on 2003 XC70]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I want to program a new ignition key into a blank ID48 transponder for my 2003 XC70 with VDASH and bought credit for it but I don't manage to have it done correctly.<br />
First I could not get the CEM PIN decoded from VDASH which stated that it could not decode from my ECU/CEM model. I managed to get the CEM PIN using OpenMoose Renatus as described here (<a href="https://forum.d5t5.com/topic/311/guide-how-to-obtain-the-cem-pin-on-any-prefl-p2-s60i-s80i-v70ii-xc70i-xc90i-my-1999-2004-in-around-60-seconds">https://forum.d5t5.com/topic/311/guide-how-to-obtain-the-cem-pin-on-any-prefl-p2-s60i-s80i-v70ii-xc70i-xc90i-my-1999-2004-in-around-60-seconds</a>) and enter the PIN manally in VDASH.</p>
<p dir="auto">In a second step, I tried the "Decode IMMO codes" option and the process seemed to work OK (went through one power cycling, boot, read, ...) and terminated without any error message or dialog but the "CEM IMMO" indicator on the right stayed grayed out with the mention "Missing!" but the the Home screen for the car I see "Immobiliser code: IMMO code is available".</p>
<p dir="auto">I only need to program the ID48 and don't care about the remote. I still have a mechanical/blade key but the last key with transponder was lost.</p>
<p dir="auto">Any hint on what I can do next to fix the issue would be greatly appreciated.</p>
]]></description><link>https://forum.d5t5.com/topic/444/unable-to-retrieve-immo-key-on-2003-xc70</link><generator>RSS for Node</generator><lastBuildDate>Sat, 24 Oct 2026 05:58:52 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/444.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Oct 2026 15:24:23 GMT</pubDate><ttl>60</ttl></channel></rss>
