<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Volvo V60 P3 (2016) – Airbag Control Module, Wiring Harness and Programming]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I own a 2016 Volvo V60 P3 with the D4204T9 engine.</p>
<p dir="auto">I am experiencing problems with the SRS/airbag system. The SRS control module (part number 31429515) has already been repaired, and communication with the module has been restored.</p>
<p dir="auto">However, several fault codes remain relating to airbag and seatbelt pretensioner circuits, as well as a low supply voltage fault.</p>
<p dir="auto">I am looking for a workshop experienced in Volvo vehicle electronics, VIDA diagnostics, and troubleshooting the complete SRS wiring harness, including connectors and wiring connections.</p>
<p dir="auto">Could you please let me know if you can carry out a complete diagnosis and repair of this system?</p>
<p dir="auto">Thank you in advance. I look forward to your reply.</p>
<p dir="auto">YV1FW79C0G1293851<br />
V60 2016 D4204T9</p>
<p dir="auto">SRS-B00011B Driver Frontal Stage 1 Deployment Control . General Electrical Failures. Circuit resistance above threshold.<br />
SRS-B00021B Driver Frontal Stage 2 Deployment Control . General Electrical Failures. Circuit resistance above threshold.<br />
SRS-B00201B Left Side Airbag Deployment Control . General Electrical Failures. Circuit resistance above threshold.<br />
SRS-B00701B Driver Seatbelt Pretensioner "A" Deployment Control. General Electrical Failures. Circuit resistance above<br />
threshold.<br />
SRS-B00751B Second Row Right Seatbelt Pretensioner Deployment Control. General Electrical Failures. Circuit resistance<br />
SRS-B00791B Driver Seatbelt Pretensioner "B" Deployment Control. General Electrical Failures. Circuit resistance above<br />
threshold.<br />
SRS-B00821B Passenger Seatbelt Load Limiter Deployment Control . General Electrical Failures. Circuit resistance above<br />
threshold.<br />
SRS-U300716 Control Module Input Power ""B"". General Electrical Failures. Circuit voltage below threshold.<br />
ECU HW NUM. SW1 NUM. SW2 NUM. SW3 NUM. SW4 NUM. SERIAL NUM.<br />
CEM 31412970 31473277 151620156<br />
DIM 31394183 31453350 259369<br />
ECM 31452623 32312275 151589<br />
TCM 31397853 31657369 31397367 151500186<br />
BCM 31423348 31471025 75208282<br />
DDM 31376697 31456696 9643996<br />
PDM 31376699 31456697 9678987<br />
CCM 31398141 31443711 2001589396<br />
SAS 31313851 31334561 150616074801<br />
PSCM 31429806 31451855 152300073781<br />
SRS 31429515 31451753 11506080207<br />
PBM 31275180 31381846 31318974 100000642894<br />
PAC 31381885 31439214 1500545364<br />
PAM 31423951 31423747 151620265700<br />
CVM 31318801 31360340 31340742 215061001473<br />
IHU 31433368 31466587 31466588 31421470 31382708 56150790</p>
]]></description><link>https://forum.d5t5.com/topic/455/volvo-v60-p3-2016-airbag-control-module-wiring-harness-and-programming</link><generator>RSS for Node</generator><lastBuildDate>Wed, 04 Nov 2026 06:39:43 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/455.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2026 18:09:50 GMT</pubDate><ttl>60</ttl></channel></rss>
