<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Volvo XC40 2025 – BCM2 C006154 &#x2F; C006254 – Acceleration Sensor Calibration Failed]]></title><description><![CDATA[<p dir="auto"><strong>Title: Volvo XC40 2025 – BCM2 C006154 / C006254 – Acceleration Sensor Calibration Failed</strong></p>
<p dir="auto">Hello everyone,</p>
<p dir="auto">I am trying to resolve two fault codes on a <strong>2025 Volvo XC40 B3 Mild Hybrid</strong> using VDASH 2.0 and a DiCE interface.</p>
<p dir="auto">The BCM2 module reports the following DTCs:</p>
<ul>
<li><strong>BCM2-C006154</strong> – Lateral Acceleration Sensor – System Programming Failures – Missing Calibration.</li>
<li><strong>BCM2-C006254</strong> – Longitudinal Acceleration Sensor – System Programming Failures – Missing Calibration.</li>
</ul>
<p dir="auto">To perform the calibration, I accessed the <strong>Advanced</strong> menu in VDASH and selected <strong>"Calibrate acceleration sensors"</strong> under the <strong>Supplementary Restraint System (SRS)</strong>.</p>
<p dir="auto">However, when executing the command, VDASH returns the following errors:</p>
<ul>
<li><strong>IMMO: FAILED [0x13]</strong></li>
<li><strong>NEGATIVE [31] – ROOR – Request out of range</strong></li>
<li><strong>The command resulted in error.</strong></li>
</ul>
<p dir="auto">VDASH also displays a warning that the <strong>VGM / firewall security key has not been found</strong>, and the software is operating in limited mode.</p>
<p dir="auto">Could someone please confirm whether I am following the correct procedure to calibrate these sensors?</p>
<p dir="auto">Is the calibration supposed to be performed through the SRS module, or is there another procedure specifically for the BCM2?</p>
<p dir="auto">Could the missing VGM security key be responsible for the calibration failure?</p>
<p dir="auto">I have attached screenshots showing the DTCs, the calibration menu and the error message.</p>
<p dir="auto">Thank you in advance for your help.</p>
<p dir="auto">Best regards,<br />
Antonio</p>
]]></description><link>https://forum.d5t5.com/topic/461/volvo-xc40-2025-bcm2-c006154-c006254-acceleration-sensor-calibration-failed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 20:23:22 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/461.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2026 18:47:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Volvo XC40 2025 – BCM2 C006154 &#x2F; C006254 – Acceleration Sensor Calibration Failed on Mon, 09 Nov 2026 18:59:33 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1794250766927-vdash_2_reduzida-resized.jpg" alt="VDASH_2_reduzida.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1794250767012-vdash_1_reduzida-resized.jpg" alt="VDASH_1_reduzida.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1794250767085-vdash_3_reduzida-resized.jpg" alt="VDASH_3_reduzida.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.d5t5.com/post/1757</link><guid isPermaLink="true">https://forum.d5t5.com/post/1757</guid><dc:creator><![CDATA[4M]]></dc:creator><pubDate>Mon, 09 Nov 2026 18:59:33 GMT</pubDate></item></channel></rss>
