<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error message 0x22]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">Maby I'll have better luck here to get an answer?</p>
<p dir="auto">I did some rear breaks few days ago, and booted up laptop and loged in to Vdash, set my var to egnition 2 so I can read it , no problem there.</p>
<p dir="auto">Clicked " service job" and set my car on service mode, no problem there, but when I was done changing breaks I wanted to do " installation check" and " exit service mode" I get this error message..</p>
<p dir="auto">Anyone knows anything, made a ticket but have to wait months for an answer..</p>
<p dir="auto">Code, Failed (0x22 - Error, Condition not correct or request sequence error )</p>
]]></description><link>https://forum.d5t5.com/topic/463/error-message-0x22</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 18:59:39 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/463.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Nov 2026 07:49:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error message 0x22 on Fri, 13 Nov 2026 12:01:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/1091">@XeptiQ</a> this error might be the result of a wrong sequence of commands. After a brake job you first  pump the brake pedal a few times, then you exit the service mode, and then you perform the install check. Is the parking brake still working or do you have any error messages or DTCs now?</p>
]]></description><link>https://forum.d5t5.com/post/1777</link><guid isPermaLink="true">https://forum.d5t5.com/post/1777</guid><dc:creator><![CDATA[T5 T6 Schnappi]]></dc:creator><pubDate>Fri, 13 Nov 2026 12:01:07 GMT</pubDate></item></channel></rss>
