<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2004.5 S40 (P1): SCL config screen hangs, SCL board dead. Can VDash pair a new 31340733?]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">The car is a 2004.5 Volvo S40, second generation (P1). Engine: 5 cyl turbo. The CEM PIN is decoded and on file in my VDash account, and I have $75 of credit loaded.</p>
<p dir="auto"><strong>The problem:</strong> The steering column lock failed. The car won't start and shows the SCL/immobilizer message. I've already removed the SCL from the column.</p>
<p dir="auto"><strong>What I've tried:</strong></p>
<ol>
<li><strong>SCL disable in VDash.</strong> I connect fine and VDash reads the car. Car Configuration → Advanced → Other equipment → Steering Column Lock hangs and the screen never loads. All the other configuration screens load normally, but none of them show an SCL option.</li>
<li><strong>Emulator.</strong> I tried a cheap clone-type emulator, but it couldn't copy any code from the original unit.</li>
<li><strong>Original SCL.</strong> The circuit board is completely unresponsive, and I don't think it can be repaired.</li>
</ol>
<p dir="auto">I've read that SCL disable through the CEM only works on 2007+ CEMs (1L15Y mask), and the guides I found are written for 2009+ P1 cars. I suspect my CEM is too old for the setting.</p>
<p dir="auto"><strong>Questions:</strong></p>
<ol>
<li>Does VDash support SCL disable on this CEM, or is the hang because the parameter doesn't exist?</li>
<li>If disable isn't possible, will VDash SCU/SCL pairing work on this car with a new virgin 31340733?</li>
<li>Will pairing also work with a virgin-type emulator, meaning one that presents itself as a new SCL rather than copying the old one? If you've had a specific brand work on a P1, please name it.</li>
<li>If neither option is supported on my car, can my unused credit be refunded?</li>
</ol>
<p dir="auto">I opened a support ticket and replied to it several times but haven't heard back, so I'm hoping someone here can help. The nearest VIDA-equipped shop is an hour's tow away, so I'd like to get this sorted with VDash if possible.</p>
<p dir="auto">Thanks,<br />
Robert</p>
]]></description><link>https://forum.d5t5.com/topic/469/2004-5-s40-p1-scl-config-screen-hangs-scl-board-dead-can-vdash-pair-a-new-31340733</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 09:16:22 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/469.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2026 04:04:04 GMT</pubDate><ttl>60</ttl></channel></rss>
