<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SRS Coding]]></title><description><![CDATA[<p dir="auto">Hi everyone.<br />
I have a question, can i code SRS used SRS u it to my XC60 2013 using VDASH or they dont offer software download.<br />
Is there only the way to do is a VIDA online ?</p>
]]></description><link>https://forum.d5t5.com/topic/67/srs-coding</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 09:27:02 GMT</lastBuildDate><atom:link href="https://forum.d5t5.com/topic/67.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Feb 2025 09:15:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SRS Coding on Fri, 29 Aug 2025 05:45:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a><br />
Happy to share what I learned over the last few months from mechanics and forums on the Volvo SRS.</p>
<p dir="auto">Quite a few 2006-2011 S80, V70 and XCs use the same SRS module with part number 31264861.<br />
A gentleman stated this particular module is not VIN-specific in one of the forums.<br />
I believe this is correct as there is no VIN (in plain text) in my EEPROM dump. However, the module serial number and the TEMIC barcode code (only the first 10 characters) printed on the module label are present.<br />
This leads me to believe that the replacement unit's serial no. and TEMIC barcode should be preserved during EEPROM cloning.</p>
<p dir="auto">Regarding the microcontroller flash, inspection of the 256K flash dump (which contains the software program) reveals the presence of the module serial number, Hardware num, Diag. num, Software num. 1 and Software num. 6 reported by VDASH. However, Software num. 2 is not present in either the EEPROM or the flash.</p>
<p dir="auto">Important: I learned in another forum that changing the flash content will cause the SRS module NOT to communicate with rest of the system and there are confirmed cases.</p>
<p dir="auto">The 2012-2016 S80 uses an entirely different SRS module which is VIN specific. See this video for EEPROM editing details: <a href="https://www.youtube.com/watch?v=HhEAUVbzBIo" rel="nofollow ugc">https://www.youtube.com/watch?v=HhEAUVbzBIo</a><br />
Someone successfully replaced the S60 SRS module, seatbelts and cleared all fault codes after a minor crash: <a href="https://www.youtube.com/watch?v=n_PM_DRKoQk" rel="nofollow ugc">https://www.youtube.com/watch?v=n_PM_DRKoQk</a></p>
<p dir="auto">Regarding programmers for the microcontroller (part number 31264861,) I have seen Xprog being used. See one of the images in: <a href="https://diagmotors.ru/work-volvo-s80-31264861-srs-repair.php" rel="nofollow ugc">https://diagmotors.ru/work-volvo-s80-31264861-srs-repair.php</a></p>
<p dir="auto">Thank you for your offer to help. How can I contact you directly? I can do email and Whatsapp.</p>
<p dir="auto">Many thanks!</p>
]]></description><link>https://forum.d5t5.com/post/432</link><guid isPermaLink="true">https://forum.d5t5.com/post/432</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Fri, 29 Aug 2025 05:45:40 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 28 Aug 2025 17:03:47 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for Download links.<br />
I mainly specialise with engine ECUs cloning and repairs I have a bit clue how to solder, and I have a professional tool to do it but I don't have many experiences with Airbags<br />
my Programmer SVOD4 doesn't like Airbags but its excellent with ECUs.<br />
For Airbag crash date I am using CG100X but there is no cloning option<br />
if you struggle with soldering I more than happy to help I was ordered genuine UPA Programmer from their website with newest script catalogue, so I hope I going to sort this SRS and make some money on this vehicle</p>
]]></description><link>https://forum.d5t5.com/post/428</link><guid isPermaLink="true">https://forum.d5t5.com/post/428</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Thu, 28 Aug 2025 17:03:47 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 28 Aug 2025 15:43:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a>, my UPA-USB programmer software is a bit old. Your particular NEC microcontroller is not on the list of supported NEC microcontrollers.</p>
<p dir="auto">But I suggest you to install the latest free UPA demo version from Elrasoft (<a href="https://www.elrasoft.com/download.htm" rel="nofollow ugc">https://www.elrasoft.com/download.htm</a>) and see if your microcontroller is supported.</p>
<p dir="auto">Download the 2 items below:</p>
<p dir="auto">Free Universal Programmer Analyser - UPA v2.3 Lite 485 KB<br />
Free UPA v2.3 Lite PASSWORD Registration</p>
<p dir="auto">By the way, I spent quite a few hours without getting good solder connections to the SRS PCB board. In the last 3 months, I succeeded 3 times (read and write) out of 100 attempts with a number of modules.</p>
<p dir="auto">I will probably contact a professional to write the EEPROM binary file for me instead.</p>
<p dir="auto">If there are other ways of programming the SRS module (without soldering) such as via the module connector or OBDII port, I would love to hear about them.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.d5t5.com/post/427</link><guid isPermaLink="true">https://forum.d5t5.com/post/427</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Thu, 28 Aug 2025 15:43:29 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 28 Aug 2025 14:25:19 GMT]]></title><description><![CDATA[<p dir="auto">Thank you</p>
]]></description><link>https://forum.d5t5.com/post/424</link><guid isPermaLink="true">https://forum.d5t5.com/post/424</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Thu, 28 Aug 2025 14:25:19 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 28 Aug 2025 14:21:43 GMT]]></title><description><![CDATA[<p dir="auto">NEC IC 70F3466GC</p>
]]></description><link>https://forum.d5t5.com/post/423</link><guid isPermaLink="true">https://forum.d5t5.com/post/423</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Thu, 28 Aug 2025 14:21:43 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 28 Aug 2025 13:40:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a>, the UPA-USB programmer goes by microcontroller models (i.e. MC9S12XDT384.) Instead of the SRS module part number, can you provide the microcontroller model inside the module for me to look up?</p>
]]></description><link>https://forum.d5t5.com/post/421</link><guid isPermaLink="true">https://forum.d5t5.com/post/421</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Thu, 28 Aug 2025 13:40:10 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Wed, 27 Aug 2025 16:32:14 GMT]]></title><description><![CDATA[<p dir="auto">UPA-USB programmer is a worthing to get?<br />
I have CG100X but it won't work with Volvo 100% crash date I clear in Volvo cars make wors then was I have one Volvo xc60 to clone srs but i can't find any good programmer<br />
can you check if UPA can clone<br />
Volvo P/N P31406637<br />
Bosch P/N 0 285 012 268<br />
thank you</p>
]]></description><link>https://forum.d5t5.com/post/419</link><guid isPermaLink="true">https://forum.d5t5.com/post/419</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Wed, 27 Aug 2025 16:32:14 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Wed, 27 Aug 2025 11:22:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a>, I use a UPA-USB programmer.</p>
]]></description><link>https://forum.d5t5.com/post/418</link><guid isPermaLink="true">https://forum.d5t5.com/post/418</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Wed, 27 Aug 2025 11:22:08 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Wed, 27 Aug 2025 06:31:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/588">@2009-S80-T6-Owner</a><br />
Thats correct.<br />
May i know what type of tool you using?</p>
]]></description><link>https://forum.d5t5.com/post/415</link><guid isPermaLink="true">https://forum.d5t5.com/post/415</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Wed, 27 Aug 2025 06:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 23:39:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a>.</p>
<ol>
<li>Erase donor module EEPROM</li>
<li>Write the EEPROM content of the original module to the donor module EEPROM</li>
</ol>
<p dir="auto">Let me give that a try. Thanks muchly!</p>
]]></description><link>https://forum.d5t5.com/post/414</link><guid isPermaLink="true">https://forum.d5t5.com/post/414</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Tue, 26 Aug 2025 23:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 17:16:17 GMT]]></title><description><![CDATA[<p dir="auto">you need to clone whole of the data from original unit ( MC9S12XDT256VAL ) to the donor,<br />
make sure you erase donor 16 Bit Microcontroller ( MC9S12XDT256VAL ) before writing original data</p>
]]></description><link>https://forum.d5t5.com/post/413</link><guid isPermaLink="true">https://forum.d5t5.com/post/413</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Tue, 26 Aug 2025 17:16:17 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 15:02:37 GMT]]></title><description><![CDATA[<p dir="auto">Below are the details for my original SRS module-</p>
<p dir="auto">Part number: 31264861<br />
Serial number: 008101000245<br />
TEMIC barcode: FBV8K10A7L</p>
<p dir="auto">Donor module details-</p>
Serial number: 007112500211<br />
TEMIC barcode: FBV7L25A6J</p>
<p dir="auto">Both the serial number and the TEMIC barcode are in the EEPROM.</p>
<p dir="auto">I have a programmer that can read the 4KB EEPROM of the MC9S12XDT256VAL micro-controller inside.</p>
<p dir="auto">Advice welcomed (i.e. which part of the original module EEPROM content should be cloned into the donor module EEPROM...etc.)</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.d5t5.com/post/412</link><guid isPermaLink="true">https://forum.d5t5.com/post/412</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Tue, 26 Aug 2025 15:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 14:15:15 GMT]]></title><description><![CDATA[<p dir="auto">ok so that's change everything. with U300000 you want to be able to clone your original SRS it must be done on the bench. what is your original part number</p>
]]></description><link>https://forum.d5t5.com/post/411</link><guid isPermaLink="true">https://forum.d5t5.com/post/411</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Tue, 26 Aug 2025 14:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 12:28:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a>.</p>
<p dir="auto">My original SRS module is showing the SRS-U300000 (internal communications error) which indicates a hardware problem although my car was never involved in any accident. That's why I inquired about how to make a donor module work with my car using VDASH.</p>
<p dir="auto">Thanks again.</p>
]]></description><link>https://forum.d5t5.com/post/410</link><guid isPermaLink="true">https://forum.d5t5.com/post/410</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Tue, 26 Aug 2025 12:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 11:20:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/588">@2009-S80-T6-Owner</a><br />
If you have original srs unit with crash date leve in the car plug in obd scanner and go to BCM and restore crash date than connect Vdash and go to srs module and choose crash date reset then run the process and it should work</p>
]]></description><link>https://forum.d5t5.com/post/409</link><guid isPermaLink="true">https://forum.d5t5.com/post/409</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Tue, 26 Aug 2025 11:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Tue, 26 Aug 2025 00:30:19 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/221">@radoslaw317</a> for your reply and congratulations on resolving your Volvo electronic issues!</p>
<p dir="auto">Per your recommendation, I will get a used module with the same Volvo part number as my original SRS module for replacement.</p>
<p dir="auto">I was carefully reading your detailed post (from 17 hours ago.) Am I right in understanding below was what you did to fix the SRS issue:</p>
<ol>
<li>
<p dir="auto">Removed the donor SRS module from the car and restored the EEPROM content to its original state (which includes the previous crash date).</p>
</li>
<li>
<p dir="auto">Use VDASH to configure the donor SRS module to work with your car.</p>
</li>
</ol>
]]></description><link>https://forum.d5t5.com/post/406</link><guid isPermaLink="true">https://forum.d5t5.com/post/406</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Tue, 26 Aug 2025 00:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Mon, 25 Aug 2025 07:44:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/588">@2009-S80-T6-Owner</a><br />
all so its highly recommend using same module as original one same part number or it want work you are cloning only to the same part number unit.</p>
]]></description><link>https://forum.d5t5.com/post/403</link><guid isPermaLink="true">https://forum.d5t5.com/post/403</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Mon, 25 Aug 2025 07:44:28 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Mon, 25 Aug 2025 07:39:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://forum.d5t5.com/uid/588">@2009-S80-T6-Owner</a><br />
Hi there configuration is not a coding you need to clone your used SRS</p>
]]></description><link>https://forum.d5t5.com/post/402</link><guid isPermaLink="true">https://forum.d5t5.com/post/402</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Mon, 25 Aug 2025 07:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Mon, 25 Aug 2025 07:35:02 GMT]]></title><description><![CDATA[<p dir="auto">solved my problem, after i repaired all deployed airbags i did crash reset by CG100X and i get crash date and ABS fault so i make worst, didn't notice that i messed up with ABS as well i thought ABS was replaced without coding before i bought this vehicle from the auction.<br />
so, after many days of fighting with this vehicle i removed SRS module and restore eeprom to previous settings with crash date and then run crash date with vdash again and then bang all sorted all faults gone ABS and SRS back to normal.</p>
]]></description><link>https://forum.d5t5.com/post/401</link><guid isPermaLink="true">https://forum.d5t5.com/post/401</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Mon, 25 Aug 2025 07:35:02 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 07 Aug 2025 22:38:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi @D5T5-David,</p>
<p dir="auto">I was reading the "Preconfiguration" section of the SRS configuration page (<a href="https://d5t5.com/article/srs-config" rel="nofollow ugc">https://d5t5.com/article/srs-config</a>) and wonder what is involved in "cloning firmware".</p>
<p dir="auto">The micro-controller inside my SRS module has a 4KB EEPROM and 256KB flash. I learned when the 256KB flash of the donor unit has been overwritten (with the content from another unit,) the module loses communication (module not found in VDASH.)</p>
<p dir="auto">In my case, both the EEPROM and flash of the donor unit were overwritten with the content of my original unit and the donor unit lost communication afterwards.</p>
<p dir="auto">Your kind help will be much appreciated!</p>
<p dir="auto">Albert</p>
]]></description><link>https://forum.d5t5.com/post/379</link><guid isPermaLink="true">https://forum.d5t5.com/post/379</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Thu, 07 Aug 2025 22:38:41 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Thu, 24 Jul 2025 10:09:34 GMT]]></title><description><![CDATA[<p dir="auto">@D5T5-David Hi David.<br />
thank you for your replay i just seen your text i though you guys dont going to reply, can you tell me when i can find ticket ID please.</p>
]]></description><link>https://forum.d5t5.com/post/363</link><guid isPermaLink="true">https://forum.d5t5.com/post/363</guid><dc:creator><![CDATA[radoslaw317]]></dc:creator><pubDate>Thu, 24 Jul 2025 10:09:34 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Sun, 13 Jul 2025 14:53:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone, I was wondering if the following are the correct steps to use "Configure SRS" to code a new/used module (part no. 31264861 or 31288291) to work with my 2009 S80 T6?</p>
<ol>
<li>Install the new/used module,</li>
<li>In VDASH, click on the SRS module to bring up the "Supplementary Restraint System" dialog, click "Configure SRS".</li>
</ol>
]]></description><link>https://forum.d5t5.com/post/344</link><guid isPermaLink="true">https://forum.d5t5.com/post/344</guid><dc:creator><![CDATA[2009 S80 T6 Owner]]></dc:creator><pubDate>Sun, 13 Jul 2025 14:53:18 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Mon, 03 Mar 2025 07:32:30 GMT]]></title><description><![CDATA[<p dir="auto">Also can you please connect the car in some near future so we have fresh data?</p>
]]></description><link>https://forum.d5t5.com/post/132</link><guid isPermaLink="true">https://forum.d5t5.com/post/132</guid><dc:creator><![CDATA[David D5T5 dev]]></dc:creator><pubDate>Mon, 03 Mar 2025 07:32:30 GMT</pubDate></item><item><title><![CDATA[Reply to SRS Coding on Mon, 03 Mar 2025 07:51:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I've checked and looks like there's communication fault with the SRS. We are checking it now. Can you please send me your ticket ID?</p>
]]></description><link>https://forum.d5t5.com/post/131</link><guid isPermaLink="true">https://forum.d5t5.com/post/131</guid><dc:creator><![CDATA[David D5T5 dev]]></dc:creator><pubDate>Mon, 03 Mar 2025 07:51:16 GMT</pubDate></item></channel></rss>
