238 Posts 125 Posters 68.2k Views
    replied to natito on last edited by
    #196
    @natito
    I already send it in chat.
    • Y Offline
      Y Offline
      you54f
      working fine reading the car but i get a null pointer exception when loading the information tab or via a dtc -> fault tracing. i also have this on another version of vida, so unsure if these are meant to work. looks so on vida youtube videos
      Y 1 Reply Last reply
        Dippa
        Installation went well and provided guide was easy to follow. Vida seems to work even with my native language, except that zoom error with network view. Latest windows 11 and updates as of 9/2026. My cheap china jlr2534 pro cable doesn't seem to work with win 11 and it won't read anything with vida, i can see it with vida but can't read vin or won't connect with hand written vin. Also tested the cable with Vdash and it reads vin but won't connect further. Later tested both programs with my friends mongoose cable and it worked fine so i have to order new one. Very much thanks for this package!
        • G Offline
          G Offline
          Glenn.M
          Er Da en venlig sjæl da kan hjælp med at installer programmet på min computer. Via fjernstyring. Da jeg ikke kan få min til at gør det. Og har givet op nu. Den vil bar ikke en skid. Skiv på Mail glennknudsen1@gmail.com Vis du / jer. vil hjælpe mig. Til det har Vida Tester har. 🙂 M.v.h Glenn
            Raidalas
            Working perfectly with win 11 + rep to this guy for even helping live 🙂
            • 0 Offline
              0 Offline
              0laf
              Runs great here. 🙂
              • Y Offline
                Y Offline
                you54f
                replied to you54f on last edited by
                #202
                Just to say, that I have reinstalled it on another machine, and able to open the information tab without getting null pointer exceptions. Will take a look at my original install to see if I can resolve.
                Thanks again, this is an outstanding contribution to the Volvo community
                  NJ
                  Hi ZaanTerror.
                  Would like to test run your program.
                  Questions first, will this be able to install straight on a windows 11 laptop, and will it also be able to be connected to internet whiles having the program installed or will this corrupt anything?
                  Many thanks and regards!
                  0 1 Reply Last reply
                  • Y Offline
                    Y Offline
                    you54f
                    #204
                    removed and reinstalled on the first machine i tried ( panasonic toughbook fz-g2 ) and the java errors are gone on the info tab. thanks again
                    • 0 Offline
                      0 Offline
                      0laf
                      replied to NJ on last edited by
                      #205
                      @NJ said in VIDA 2014D/2015A Windows 11:
                      Hi ZaanTerror.
                      Unless you have a webserver on your laptop it will run just fine.
                        Mykola PL
                        replied to ZaanTerror on last edited by Mykola PL
                        #206
                        @ZaanTerror Hello, I would be very happy if you provided me with the VIDA software. Thanks in advance! hotsky86@gmail.com
                          Mykola PL
                          The installation went smoothly. I ran into a few SQL issues, but those were caused by my computer. I installed it on drive D since it wouldn't install on drive C. It's up and running now, and I'm really enjoying it 😉
                            Tbear
                            @ZaanTerror Hi, I would be very happy if you could provide the VIDA software for me 🙂
                              Bartekb
                              Hey @ZaanTerror , great work, I would be very happy if you provided me with the VIDA software. Thank you in advance
                              B 2 Replies Last reply
                                liamstears
                                Recently installed this, worked perfectly first time on Windows 11, works exactly as expected with no notable issues other than the usual niggles like having to right click on vehicle communication to select a module
                                Thank you 👍🏻
                                  NJ
                                  Windows 10 user here, thanks for the work you have done. Not been able to test all functions yet, but the ones ive done has all worked properly. Running with the JLR moongoose cheap version from China, and its fast and giving zero issues this far. Thanks again, will update i find any issues.
                                    Pakas
                                    Confirmed. Win10 Home with JLR moongoose from China works perfectly. Thank you @ZaanTerror and the rest of the forum members for the good work.
                                    • G Offline
                                      G Offline
                                      Gajcov
                                      Hi, could you also provide me the files via mail 😄 lolbrando@wp.pl. Thank you @ZaanTerror in advance
                                      • H Offline
                                        H Offline
                                        heavyheadz
                                        This post is deleted!
                                        • H Offline
                                          H Offline
                                          heavyheadz
                                          Worked well, thanks @ZaanTerror
                                          • 12
