@ZaanTerror I just did another unplanned test and revived a completely borked VIDA Installation on an old WIN 10 Laptop thanks to your work and effort. Same issues. Empty Software tab and short lags/freezes in the parts catalogue when you click on the position numbers of any part in the parts diagrams. But still great responsiveness and speed compared to an original VIDA 2014D.
Will test your new version tomorrow. -
@ZaanTerror finally found the time to do some testing of your latest version (03.02.26 from MEGA).
Clean install worked flawless, as usual.
Playing a little on a 2001 S60 and a 2018 V60CC(P3) didn't bring up any problems. Diagnostics, parts catalogue and service functions were working as expected.
Good work!!! -
@T5-T6-Schnappi : so the 2018 models are recognized in this version of Vida? it's not limited to 2015 only?
@sizan this version is patched to support some P1 and P3 cars up to 2019. But for my V60CC with a VEA engine I have to use a workaround. Cross Countrys are only supported in the US partner group, and only with 5 cylinder petrol engines. The workaround is explained here https://svdns.info/2022/01/15/using-vida-2014d-with-an-unsupported-vin/
T T5 T6 Schnappi referenced this topic
26-02-2026 UPDATE:
Improved installation and uninstallation sequence.
Upgraded to SQL Server 2025 Standard Developer.
Upgraded JBoss EAP to version 8.1 update 4.(latest version available today)The download link will stay the same, when you download again you will have the newest version.
Thank you for this release of Vida together with Windows 11. It was just to unzipping the file and starting the installation, and after a while everything was up and running since you had also attached the other files that you otherwise had to download yourself.
So again, a BIG THANK YOU for this
