Vdash with Scanmatk3
7 Posts 4 Posters 815 Views
    marek113k
    Good morning,
    have someone work on Vdash via Scanmatik3 hardware?
      Beared81
      I tested with Scanmatic 2 and it works perfectly on P3 platform.
      So scanmatic 3 wil lwork well there. I am not sure if newer stuff works on scanmatik 3 but if anything will work it it likely that. Scanmatik 2 worked perfectly with VIDA2014D as it was designed for so I might be a question to ask the developer or test yourself.
      Scanmatik SM3 Pass-Thru adapter is a successor of SM2Pro adapter with CAN-FD and DoIP protocols. It offers widest support for SAE J2534-1/2 and TMC RP1210 standard features.
      • C Offline
        C Offline
        Ctrl-alt-delete
        I have a faulty - 2016 XC90 D5 - D4204T11 engine 2.0L four-cylinder twin-turbo diesel - Diagnostics Cable
        I've made a cable that does both CAN and DOIP and written some software to interrogate the Volvo XC90 MK II D5 AWD, it is in early test but looking promising, and it runs on Ubuntu Linux.
        My motivation for doing this is that my XC 90 that I owned from new has had some issues and is in Turtle / Tortoise mode with the only error P0100 Pending (MAF Malfunction)
        I've recently fixed all leaks around oil pipes near turbo and had Exhaust Manifold gasket replaced because bolts came loose. It had a new Inlet Manifold under warranty at 97K Miles, and now at 140K has had Walnut Blasting, EGR Valve and Cooler replaced, Pressure Sensor Replaced.
        My diagnostics is showing an imbalance of Block temp to thermostat temperature on cooling system which I think is main issue now, 1st I will bleed and top up system
        If anyone knows what the DID codes represent below that would be very helpful.
        • 0x40E2
          • 0x4311
          • 0x42ED
          • 0x42EE
          • 0x411D
          • 0x438B
        Parts required for the cable -
        510 Ohm Resistor
        Female RJ45 Connector.
        ODB2-Cable
        CAN Adapter
        Use a small straight through RJ45 cable 0.5m to your laptop.
        Option 1 - ODB 2 to - Female RJ45
        Pin 3 (RX+) - 1 - on the Female RJ45
        Pin 11 (RX-) - 2
        Pin 12 (TX+) 3
        Pin 13 (TX-) - 6
        The Resistor goes between pin 8 Activation and 16 is 12v this is needed to bring the IP live.
        For the CAN - DSD TECH SH-C31G Isolated USB to CAN Adapter with FD Support Based on Canable 2.0 Pro
        GND is Yellow and Orange ODB2 pins 4+5
        CAN-H is Green - ODB2 - pin 6
        CAN-L is Red/White - ODB2 - pin 14
        IMPORTANT - Use a Multi-meter to check wires against pins, suppliers colours may change.
        I was hoping I could program keys and maps with this set up but it seems Volvo locked it down and I need other things.
        Will the cable I made work with VDASH for my 2016 SPA?
        I've written basic software for Ubuntu Linux to diagnose the car, I record history of all feeds from cable every 1s then analyse.
          replied to Ctrl-alt-delete last edited by
          @Ctrl-alt-delete if your cable 100% supports the DoIP, or the J2534-2 protocol (including compatible Windows J2534-2 drivers), you should be able use it with vdash or orbit. But as it sounds more like you have made a CAN bus sniffer, I doubt it.
          To program keys, you will need several security pins to get write access to several ecus. Not 100% sure what is needed on the SPA plattform, but IMMO and KVM pin are definitely needed, and can't be cracked with Vdash. Maybe you also need the CEM pin, which has a 50/50 chance to be crackable with Vdash with a really good J2534 adapter and lots of patience.
          There are even more pins in your car, and all if them are unique for your car. The only way to extract most of them is on the bench or by using man-in-the-middle techniqes while the car is being programmed with a legit version of VIDA. On SPAs/CMAs from 2022 onwards it became even worse because of a hardware firewall behind the OBD socket.
          • C Offline
            C Offline
            Ctrl-alt-delete
            @T5-T6-Schnappi yes, it is a sniffer and a DOIP reader. My main aim when I started was to read info and faults from the car, I have lots of data now and an ongoing issue that I am hoping replacing the MAF will solve. Volvo original is over £400 GBP, I tried one cheaper off eBay and the values were higher than the faulty one.
            I am consistently getting P0100 fault pending and turtle
            • C Offline
              C Offline
              Ctrl-alt-delete
              I will try and figure out other things. What makes the J2534-2 protocol different from what I made?
              I have another ECU I got from a scrap car to play with on bench going to see what I can do.
                @Ctrl-alt-delete before you start to fire the parts canon, you should know that 90%of all MAF codes are follow up errors of other problems. Old/weak batteries, dirty MAP sensor, dirty throttle body, carbon build up in the EGR/EGR cooler. There is also a technical journal about a design flaw in the EGR cooler of older VEA diesels, that triggers P010000 and requires replacing EGR and cooler with redesigned parts.
                The data you have collected is also not really useful, unless you find the signal specifications of the ECM, to check if everything is in the desired range. This data can be found in the online version of VIDA which is not accessible for private user, unless you live in the US. VIDA also has detailed explanations what triggers code XYZ and an associated fault trace with things to check, to find the cause for the code. This kind of vital information can hardly be found in the internet.
                You also should know that Volvos don't like aftermarket sensors. Replacing the MAF with an aftermarket part might not solve your issue, if it's really the MAF.
                Your first step should be to get a good Volvo capable diag tool and scan the car with that. Not only the ECM, all ecus. A dead battery for example will trigger several communication codes in several ecus. You should also take a look at the freeze frame data, that is stored together with the code and consists of a set of data/parameters that happened in the moment when the code was stored, which could be helpfull to identify some problems.
                The J2534 is a complicated SAE standard that describes/specifies all kinds of communication protocols between all ecus in your car and a computer through a VCI. Dataformats, bitrates, commands, timings, signaling specifications and what not for programming, diagnostics, activations and so on. Substandards are J2534-1 for ECMs, J2534-2 for all other ecus. Without J2534 compatible firmware/drivers/software, your cable won't be usable for the things you want to do.
