ECM-26B0
Scheduled Pinned Locked Moved P2 (S60, V70II, XC70, S80, XC90)
3 Posts 2 Posters 1.8k Views
  • P Offline
    P Offline
    picovix
    Hi
    these error appear only when the car is off for two minutes and then switches to injecton on. The error does not appear when the car is running.
    In DTC this error means "Injector power stage, cyl 5. Signal too high".
    I've check the cable and injector and all Is ok. If I unplug the injector 5 the error Is present. I tried swapping the cables between 4 and 5 injector and the error is ever 26B0. Could the ECM be faulty? Do you think if I reprogram it with vdash could the problem be solved?
      bambur6
      If you know how to use a translator, I recommend that you read it very carefully. not everything can be solved by flashing, sometimes you have to work with your hands.
      With best wishes.
      https://www.drive2.ru/l/654506837495792443/
      • P Offline
        P Offline
        picovix
        hi, yes I had already seen this page and changed the connectors. the injector is ok because even when I disconnect the cable the error appears. which does not happen when I disconnect the cable of injector 4. I checked the cables and also the insulation.. everything is ok. I will tell you more I get the error even if I disconnect the large connector of the ECU leaving only the small one connected which is power supply
