245 Posts 130 Posters 69.6k Views
    simlick67
    REVIEW: WOW!!!! So easy!
    Guys, I have been trying the different version of VIDA of the past years, mostly running on Virtual Machines, which sometimes did run fine, but also encountered problems and took a lot of time and reading and effort to get it working.
    This makes getting VIDA a dream... it just worked straight out the zip file (I did have 3.5 Network installed already, not the one supplied with the ZIP). I also had my own drivers for the Mongoose interface installed. Running it on a Panasonic toughbook, i5, 16gb of ram.
    I've also encountered many people selling their own easy install versions, and for quite a price too. Volvodiag offers a 5 dollar VM option, but again it's so much hassle.
    Props to Zaan, this is what a good software tech can do, and in turn makes my life much easier. I don't want to spend hours figuring out if I have the right spec, right software, right verison etc. I just need the software so I can work on my car and get on with my life. This allows you to do that.
      Vizual54
      Worked like a charm on my newly installed win 11 laptop, Dell latitude 7280, i7, 16gb ram.
      Been using VIDA in a vm on Ubuntu with virtual box and it never really worked out very well. Especially with the J2534 which would make the vm crash almost every time.
      This worked so much better and was breeze to install.
      Lots of kudos to ZaanTerror for making it so easy saving me a lot of time and frustration.
      • C Offline
        C Offline
        C0mplexed
        @ZaanTerror Can you send me the google-drive link to linus.forsman@post.com please?
          TheBeerHunter
          Very nice! Works like a charm!
            TheBeerHunter
            wrote on last edited by TheBeerHunter
            #62
            Any new update of your Vida since march 18 (last time I fixed it)?
              marconi63
              The program installed on a laptop and a desktop running Windows11 pro 25H2. It works without any issues.
              Thanks a lot.
                rewned99
                Due to illness, I only got around to testing it now. I connected the car to Vida and it works both via VirtualPC in Vmware and on a physical NTB...
                It's great when it works without problems.
                  rewned99
                  And yet...I compared it with the modified Vidov 2015A, where there is only a change to SQL2019 and everything is installed via scripts, not in one run...
                  I am not a programmer. The responses are basically the same... But this one is easier to install... and works the first time... THANKS
                    otukka12
                    Works fine after reinstalling windows. Wasn’t worked with previous setup. I think previous vida version was reason.
                    • jbruijsJ Offline
                      jbruijsJ Offline
                      jbruijs
                      @ZaanTerror I really would like to receive the link. Could you please send me this? inboxanoniem@gmail.com
                      • Y Offline
                        Y Offline
                        Yurii bihun
                        @ZaanTerror Can you send me the link to bihunyura@gmail.com?
                          teepee
                          Installation on win11 laptop was a breeze. Thank you so much for sharing!
                          • F Offline
                            F Offline
                            Fidda
                            Hi, can I please get a copy too? @ZaanTerror I would really appreciate it! Thank you so much
                            Johnpeter22759@gmail.com
                              Mykoliukas
                              Instalation went smooth. Tested on xc60 2012 with DiCE. Works perfect! Thank you!
                                LukeLucky
                                I just wanted to give a massive shoutout to the creator of this Windows 11 VIDA version.
                                I’ve been struggling with Win7 virtual machines for a long time just to keep my XC60 (2013) in check, but this build is a total game-changer. It runs flawlessly on my Win11 host—no more VM lag or USB passthrough headaches.
                                Everything works perfectly:
                                Seamless login (no issues there!).
                                Full access to all modules (CEM, BCM, PAM, etc. — all green and communicating).
                                Rock-solid stability with the DiCE interface.
                                If anyone is still hesitating: go for it. This is top-tier work that makes Volvo ownership much more enjoyable. Absolute legend! Thanks again!
                                  kvavra
                                  @ZaanTerror Can you send me the link to k.vavra@seznam.cz
                                  Thank you !
                                  • ilonapsheI Offline
                                    ilonapsheI Offline
                                    ilonapshe
                                    @ZaanTerror Can you please send me the link to ipshenichnaya6@gmail.com
                                    Thank you very much!
                                      Vinalile
                                      @ZaanTerror Is someone you really can trust, working like a charm, no issues, and no more vm struggles anymore! Big thank you sir!
                                        ilonapsheI Offline
                                        ilonapshe
                                        Hi guys!
                                        Maybe someone can help me somehow with the installation. Idk what I am doing wrong.
                                        So basically my installation process stops with Microsoft SQL server 2025. I changed the .net framework 3.5 in optional features, but it didnt help. Then I decided to install the SQL server 2025 from the https://www.microsoft.com/en-us/sql-server/sql-server-downloads. Got the program work, but the VIDA installation still stops in the same place.
                                        Thought maybe I can install everything from ISSetupPrerequisties. So i did that, even the SQL seems to work from there, but in main VIDA setup.exe it still stays as a requirment and when i start installation i got message
                                        Can someone tell me what i need to do to get VIDA work with me?
                                          replied to ilonapshe on last edited by
                                          #77
                                          @ilonapshe what version of Windows are you running? Do you try to replace an older version of VIDA or is it a clean install?
                                          ilonapsheI 1 Reply Last reply
                                          • 12
                                          • 13
