211 Posts 107 Posters 58.5k Views
    rewned99
    And yet...I compared it with the modified Vidov 2015A, where there is only a change to SQL2019 and everything is installed via scripts, not in one run...
    I am not a programmer. The responses are basically the same... But this one is easier to install... and works the first time... THANKS
      otukka12
      Works fine after reinstalling windows. Wasn’t worked with previous setup. I think previous vida version was reason.
      • jbruijsJ Offline
        jbruijsJ Offline
        jbruijs
        @ZaanTerror I really would like to receive the link. Could you please send me this? inboxanoniem@gmail.com
        • Y Offline
          Y Offline
          Yurii bihun
          @ZaanTerror Can you send me the link to bihunyura@gmail.com?
            teepee
            Installation on win11 laptop was a breeze. Thank you so much for sharing!
            • F Offline
              F Offline
              Fidda
              Hi, can I please get a copy too? @ZaanTerror I would really appreciate it! Thank you so much
              Johnpeter22759@gmail.com
                Mykoliukas
                Instalation went smooth. Tested on xc60 2012 with DiCE. Works perfect! Thank you!
                  LukeLucky
                  I just wanted to give a massive shoutout to the creator of this Windows 11 VIDA version.
                  I’ve been struggling with Win7 virtual machines for a long time just to keep my XC60 (2013) in check, but this build is a total game-changer. It runs flawlessly on my Win11 host—no more VM lag or USB passthrough headaches.
                  Everything works perfectly:
                  Seamless login (no issues there!).
                  Full access to all modules (CEM, BCM, PAM, etc. — all green and communicating).
                  Rock-solid stability with the DiCE interface.
                  If anyone is still hesitating: go for it. This is top-tier work that makes Volvo ownership much more enjoyable. Absolute legend! Thanks again!
                    kvavra
                    @ZaanTerror Can you send me the link to k.vavra@seznam.cz
                    Thank you !
                    • ilonapsheI Offline
                      ilonapsheI Offline
                      ilonapshe
                      @ZaanTerror Can you please send me the link to ipshenichnaya6@gmail.com
                      Thank you very much!
                        Vinalile
                        @ZaanTerror Is someone you really can trust, working like a charm, no issues, and no more vm struggles anymore! Big thank you sir!
                          ilonapsheI Offline
                          ilonapshe
                          Hi guys!
                          Maybe someone can help me somehow with the installation. Idk what I am doing wrong.
                          So basically my installation process stops with Microsoft SQL server 2025. I changed the .net framework 3.5 in optional features, but it didnt help. Then I decided to install the SQL server 2025 from the https://www.microsoft.com/en-us/sql-server/sql-server-downloads. Got the program work, but the VIDA installation still stops in the same place.
                          Thought maybe I can install everything from ISSetupPrerequisties. So i did that, even the SQL seems to work from there, but in main VIDA setup.exe it still stays as a requirment and when i start installation i got message
                          Can someone tell me what i need to do to get VIDA work with me?
                            replied to ilonapshe on last edited by
                            #77
                            @ilonapshe what version of Windows are you running? Do you try to replace an older version of VIDA or is it a clean install?
                            ilonapsheI 1 Reply Last reply
                            • 3 Offline
                              3 Offline
                              314159
                              Thank you very much, great job!
                              Very easy installation of the program.
                                Kaaliperse
                                Hello
                                May i get the download link for this perhaps?
                                BR
                                Kaaliperse
                                  Smuggler44
                                  Hi
                                  Could i get the download link 🙂
                                  Best regards
                                  Dawid
                                    ilonapsheI Offline
                                    ilonapshe
                                    #81
                                    @T5-T6-Schnappi It is a clean install on my personal laptop(work and one game). I have Windows 11 25H2
                                      #82
                                      @ilonapshe try the following:
                                      press Windows-key+r and enter services.msc
                                      stop all SQL* services
                                      uninstall everthing with SQL in its name via control panel
                                      reboot the computer
                                      manually delete the folders "C:\Program Files (x86)\Microsoft SQL Server" and "C:\Program Files\Microsoft SQL Server"
                                      download the archive again (I send you a link via PM) and unpack it with the latest version of 7-Zip
                                      permanently disable any 3rd party Antivirus/Security software until VIDA is installed
                                        ilonapsheI Offline
                                        ilonapshe
                                        The program installation issue was resolved. It turns out I needed to reboot the laptop before installing the SQL servers.
                                        But apparently the obstacles aren't over for me. I have a Chinese clone of DiCE that I got with the previous VIDA program, which crashed on Windows 7. And for some reason, I can't run diagnostics on the car. The laptop sees DiCE, but I can't read the car. I installed Scanmatic (it was on the old laptop, and as far as I understand, DiCE used to see cars with it), but it didn't yield any significant results. Now DiCE is simply visible as a Scanmatic device, not "unknown," and in VIDA, I can now select CM2 USB/CM3 USB devices.
                                        Can you tell me how to properly connect and configure the Chinese DiCE so I can start seeing cars? I'm just a girl in the world
                                          #84
                                          @ilonapshe As it seems, your DICE is a Scanmatic SMII in a DICE shell which is suboptimal in many ways. What car do you try to scan.
                                          Select the CM2/CM3 in VIDA and click on read next to this. You need to log in with the correct market/partner group or your car won't be recognized/decoded.
                                          Could you please download and install Vdash and try to connect to your car with that. To see if your adapter is working. It's easier this way than with VIDA.
