280 Posts 151 Posters 85.7k Views
    SOUTHPARK
    Hi, my first testing was on WIN 11 64bit 24H2. Installation is done without any problem. Incredible work, Mr. programmer 🙂 Once again, a very big THANK YOU. Many years suffering with installations errors are a thing of the past. You are GREAT!!!
      Radurov
      Hello @ZaanTerror
      Please send me the installation link to radu.chereches@gmail.com
      Thanks.
        Di5B
        Overall, it works, but sometimes I can't enable diagnostics... and I constantly have to stop services via cmd...
          replied to Di5B on last edited by
          #106
          @Di5B Do you run VIDA on native hardware or in a VM? Dedicated VIDA machine, or is it your everyday computer with lots of other software installed and lots off unnecessary background processes? Is any 3rd party antivirus or security software installed? What hardware specs?
          • ilonapsheI Offline
            ilonapsheI Offline
            ilonapshe
            Troubles troubles and troubles.
            Finally got the Mongoose(obviously from aliexpress). laptop sees it. VIDA sees it. But when I try do diagnostic to my XC70 2006 VIDA says that all mongoose device is in-use by other app. I have only VIDA and Vdash installed from here and can't figure out how I can resolve that problem.
              SU-AM
              Many thanks for the software. It works perfect.
                KonK
                I am having an issue while trying to install the software. its give ng me an error " The Installation of Microsoft SQL Server 2025 Standard Developer (x64) has failed. Setup will now exit. Can someone please help?
                  notr
                  Hello, can I please get the Google Drive download link for VIDA? Thank you
                    replied to KonK on last edited by
                    #111
                    @KonK Do you try to replace an existing VIDA or is it a clean install? Do you want to install it in a virtual machine or on native hardware? What version of Windows?
                    Please locate the following folder: C:\Program Files\Microsoft SQL Server\170\Setup Bootstrap\Log , there should be one or more subfolders with date and time as name, open the newest one and locate the file named "Detail.txt". It should have details what is the problem somewhere at the end.
                      jexyq
                      I'm trying to use VIDA 2014D with a Mongoose Pro JLR interface on a 2007 Volvo V70.
                      The connection itself seems to work:
                      • VIDA loads the Mongoose driver correctly
                      • VIN is successfully read
                      • the vehicle gets identified correctly
                      However, I have a strange issue with VIDA itself:
                      After logging in:
                      • both "Information" and "Diagnostics" tabs are greyed out.
                      After identifying the vehicle:
                      • "Information" becomes available,
                      • but "Diagnostics" remains permanently greyed out/unavailable.
                      So the problem does NOT seem to be complete communication failure, because VIDA can clearly talk to the car and read the VIN.
                      Has anyone seen this before?
                      Any ideas would be greatly appreciated.
                      O 1 Reply Last reply
                        odder
                        replied to jexyq on last edited by
                        #113
                        @jexyq Hi, happened to me once before. I unplugged everything, shut off the car, restarted the PC. Then -> car ignition, plug in JLR, plug in USB (get a USB device notification), start vida, and be very patient. I manually typed in my VIN at VIDA profile.
                        J 1 Reply Last reply
                          jexyq
                          replied to odder on last edited by
                          #114
                          @odder Thanks for the suggestion!
                          I actually just tried exactly what you described, step by step and in that precise order, but unfortunately, nothing changed. In my case, I have never been able to get it to work even once, which makes me think the problem might lie somewhere deeper.
                          Thanks for the quick reply tho, really appreciate it!
                            #115
                            @jexyq does the car communicate with Vdash through your adapter?
                            Are you able to enter the diagnostic tab "offline" with no car connected? If you just enter your VIN or just define your car without the VIN, and than click ok?
                            Are you using the correct login? You need to login to the correct partner group which equals the market your car was initially meant for. Never use "Admin".
                            Have you tried to disable VIN decoding by going to computer settings in VIDA and then manually entering the VIN (VIN Dekoder off in red letters must be shown next to the VIN boxes), specify your car, then enter ok (don't click read next to the communication tool!), and than go to the diagnostic tab? This works even on most P1 and P3 cars that are officially not supported by VIDA2014D. As long as your adapter works.
                            What are your hardware specs CPU, RAM, SSD? VIDA requires a fast SSD and 4 or more GB of RAM to be halfway responsible. Maybe you need to be more patient for the diag database to load. This sometimes takes a several seconds even on my fastest computer with 16GB RAM and really, really fast NVMe SSD.
                            Are you sure that your adapter is okay? Most Mongoose clones from aliexpress, for example, don't have the original Atmel chipset or even a mongoose at all inside their chassis and are basically dead on arrival or don't work as expected. Mostly those garbage adapters don't properly communicate with either the HS or LS CAN leading to exactly the problem you have. VIN gets recognized. But full Diagnostics/Communication with the car is impossible.
                              jexyq
                              #116
                              Yes, VDash works perfectly through the adapter.
                              I don't really understand how that would work offline. I assumed the car has to be connected in order to access Diagnostics. In any case, I tried entering the VIN manually both with the car connected and with the cable disconnected, and it still doesn't work.
                              Yes, I'm using INT, which is the correct partner group for my car, at least according to the D5T5 lookup tool.
                              I just tried your procedure step by step: disabled VIN Decoder, entered the VIN manually, specified the car, clicked OK without using the "Read" button next to the Communication Tool. Unfortunately, Diagnostics tab is still grayed out.
                              My hardware isn't the greatest (Intel Celeron N2840 @ 2.58 GHz, 8 GB RAM, SSD), but I waited for about 30 minutes, so I doubt it's simply a matter of the diagnostic database taking time to load.
                              As for the adapter, I believe it's fine. Both HS-CAN and LS-CAN work perfectly in VDash, so the adapter itself and the drivers seem to be communicating with the car correctly.
                                #117
                                @jexyq I would suspect your installation to be somehow borked then. You can use most functions of VIDA without being connected to a car. If diagnostics still don't work that way, it's time for a re-install.
                                Stop VidaMonitor
                                Exit VidaMonitor
                                Uninstall VIDA
                                Unistall SQL Server
                                Unistall everything else with SQL in it's name
                                Unistall Isoview
                                Reboot the computer
                                Delete all folders containing VIDA, Volvo, Ford, Isoview in their name
                                Delete : C:\Program Files\Microsoft SQL Server
                                Reboot again
                                Install VIDA from scratch
                                Your Hardware is not the best, but good enough to run VIDA.
                                  #118
                                  @jexyq Oh, and you have to reboot your computer after you have used Vdash before you can use VIDA, and vice versa. Don't ask me why. It's like this on many but not all of my computers.
                                    ElThomas
                                    Need the vida software link as well
                                      Bobeee
                                      Hi people,
                                      Is this software specifically for Windows 11, or can it be used on older windows versions/VirtualBox?
                                      And if only Win11, does it have full functionality i.e. Diagnostics/Vehicle communication/Advanced... shows the VCT2000 button to initiate process?
                                      I have vida 2014D installed on an old Win7 laptop but for some reason it has stopped showing the VCT2000 button/icon to start diagnostic processes. I wanted to do a forced DPF regeneration but as well as the VCT2000 icon not showing it also has nothing to the right of the advanced tap in vehicle communication. I beleive this is something to do with ActiveX controls being blocked.
                                      So after hours of messing about I came to the conclusion that a Vida version for virtualBox should solve all my issues. That is until I saw this version for Win11.
                                      Some helpful advice would be mucho gracias... 🙂
                                      TIA
                                        replied to Bobeee on last edited by
                                        #121
                                        @Bobeee This version of VIDA is heavily modernized "under the hood" to work on 64bit Windows 10/11 only. And running VIDA in a VM is not recommended at all, even if it works. You can create a Windows To Go USB drive or stick with this tool and run VIDA from that, if you want to run a VIDA only environment.
                                        Everything works exactly the same as all other versions of VIDA2014D. Just the VIN decoder is extended to recognize some P1s and P3s up to modelyear 2019.
                                        The hardware requirements are slightly higher than for the original VIDA2014D as the SQL server is updated from SQL 2008 to SQL 2025. As well as a lot of other things that are replaced with more modern versions.
                                        Of course software updates/reloads don't work like all other offline VIDAs.
                                        The Installer made by ZaanTerror makes it really easy to install if you do a clean install btw.
                                        Replacing an existing VIDA requires a little effort before you can install the new version.
                                          jexyq
                                          #122
                                          @T5-T6-Schnappi Hi,
                                          I did a clean install and tried all the steps you suggested. I’m pretty sure the issue was actually on my side - I hadn’t manually filled in the dropdown lists for Transmission, Steering, and Body style.
                                          I can’t be 100% certain if that was the only problem, because I ran out of patience and installed Windows 7, so I can’t confirm if it would have worked on Windows 10 - but I’m about 90% sure it would have.
                                          Bit embarrassing how it turned out… anyway, thanks a lot for all your help.
                                          • 13
                                          • 14
