114 Posts 55 Posters 12.0k Views
    Eros
    wrote last edited by Eros
    #101
    Thank you again ZaanTerror, I got the VIDA software working on my windows 11 with a clone mongoose scanner, but I think there's only 2 things that I would probably change because it took me a while to get it running, maybe add a step by step install guide (I know we just need to run the setup.exe, but it didn't work out for me) and possible fixes if something doesnt work like it should (in a .txt file)? I had some problems with my java, SQL and with the login screen saying the language I had installed didn't match the language I was trying to login with, but i was selecting all the right stuff, in the end I did manage to fix everything with the help of ChatGPT, maybe if I had installed it in a fresh windows it would've went just fine, but since mine and probably most people downloading it isn't I guess it would've been probably easier if there were some guide in fixing common errors or whatever, but thanks a lot again!
      replied to Eros last edited by
      #102
      @Eros Install guides in english and german for clean installs can be found here
      If you have any useful additions just let me know them.
      If you want to replace an existing VIDA2014D installation, you need to fully remove that first. You have to stop and close VidaMonitor; stop all running SQL services; uninstall VIDA, Isoview, everything with SQL in it's name; reboot your computer; manually remove all folders containing the terms VIDA, Volvo, Ford, Isoview, SQL, Arbortext, also those that are hidden in various locations; check the Registry for leftovers and also delete them; reboot the computer again; then start ZaanTerrors Installer. Maybe I will write guide for this when I find the time and motivation to do it and add it to the install guides.
      As a golden rule you shouldn't use your everyday computer for VIDA. It's better to use a dedicated machine for VIDA or create a Windows 2 Go USB drive and run VIDA from that, when your computer is already cluttered with all kinds of installed software.
      The more stuff you have installed besides VIDA, the more things can and will interfere with it. Especially 3rd party antivirus/security softwares and the damages done to Windows by so called optimization/tuning softwares could give you a hard time trying to get VIDA up and running.
        SOUTHPARK
        Hi, my first testing was on WIN 11 64bit 24H2. Installation is done without any problem. Incredible work, Mr. programmer 🙂 Once again, a very big THANK YOU. Many years suffering with installations errors are a thing of the past. You are GREAT!!!
          Radurov
          Hello @ZaanTerror
          Please send me the installation link to radu.chereches@gmail.com
          Thanks.
            Di5B
            Overall, it works, but sometimes I can't enable diagnostics... and I constantly have to stop services via cmd...
              replied to Di5B last edited by
              #106
              @Di5B Do you run VIDA on native hardware or in a VM? Dedicated VIDA machine, or is it your everyday computer with lots of other software installed and lots off unnecessary background processes? Is any 3rd party antivirus or security software installed? What hardware specs?
              • ilonapsheI Offline
                ilonapsheI Offline
                ilonapshe
                Troubles troubles and troubles.
                Finally got the Mongoose(obviously from aliexpress). laptop sees it. VIDA sees it. But when I try do diagnostic to my XC70 2006 VIDA says that all mongoose device is in-use by other app. I have only VIDA and Vdash installed from here and can't figure out how I can resolve that problem.
                  SU-AM
                  Many thanks for the software. It works perfect.
                    KonK
                    I am having an issue while trying to install the software. its give ng me an error " The Installation of Microsoft SQL Server 2025 Standard Developer (x64) has failed. Setup will now exit. Can someone please help?
                      notr
                      Hello, can I please get the Google Drive download link for VIDA? Thank you
                        replied to KonK last edited by
                        #111
                        @KonK Do you try to replace an existing VIDA or is it a clean install? Do you want to install it in a virtual machine or on native hardware? What version of Windows?
                        Please locate the following folder: C:\Program Files\Microsoft SQL Server\170\Setup Bootstrap\Log , there should be one or more subfolders with date and time as name, open the newest one and locate the file named "Detail.txt". It should have details what is the problem somewhere at the end.
                          jexyq
                          I'm trying to use VIDA 2014D with a Mongoose Pro JLR interface on a 2007 Volvo V70.
                          The connection itself seems to work:
                          • VIDA loads the Mongoose driver correctly
                          • VIN is successfully read
                          • the vehicle gets identified correctly
                          However, I have a strange issue with VIDA itself:
                          After logging in:
                          • both "Information" and "Diagnostics" tabs are greyed out.
                          After identifying the vehicle:
                          • "Information" becomes available,
                          • but "Diagnostics" remains permanently greyed out/unavailable.
                          So the problem does NOT seem to be complete communication failure, because VIDA can clearly talk to the car and read the VIN.
                          Has anyone seen this before?
                          Any ideas would be greatly appreciated.
                          O 1 Reply Last reply
                          • O Online
                            O Online
                            odder
                            replied to jexyq last edited by
                            #113
                            @jexyq Hi, happened to me once before. I unplugged everything, shut off the car, restarted the PC. Then -> car ignition, plug in JLR, plug in USB (get a USB device notification), start vida, and be very patient. I manually typed in my VIN at VIDA profile.
                            J 1 Reply Last reply
                              jexyq
                              replied to odder last edited by
                              #114
                              @odder Thanks for the suggestion!
                              I actually just tried exactly what you described, step by step and in that precise order, but unfortunately, nothing changed. In my case, I have never been able to get it to work even once, which makes me think the problem might lie somewhere deeper.
                              Thanks for the quick reply tho, really appreciate it!
