Error after headlight replacement
2 Posts 2 Posters 10 Views
    Zwergnase
    I have a 2007 model year V70 with standard Xenon headlights (reflector type), and I’ve just installed Xenon headlights (projector/lens type) with the cornering light function.
    I’m getting a "Headlight Malfunction" error because the car isn't equipped for cornering lights, causing the headlights to constantly move to the emergency position (pointing down).
    The adjustment motors are working, as the headlights do move up and down.
    Can the system be reprogrammed so the car thinks it only has the standard headlights? Or is it possible to simply activate the cornering light function—even though it won't actually work and I don't need it—just to clear the error?
    Many thanks for your tips.
      replied to Zwergnase last edited by
      @Zwergnase The ABLs need the HCM module which isn't present on normal Xenons, additional wiring and a configuration change which requires the CEM pin.
