XC90 SPA 2016 UK Headlight swap to EU Help
8 Posts 3 Posters 841 Views
    Searchy
    Hi all,
    I have a 2016 UK model XC90 Inscription which i have brought to Spain and we want to keep it, but to meet the Spanish law for registering it legally, the beam pattern requires adjustment and on the car this is not possible, took it to a Volvo dealer in Spain and they stated the headlights require replacing, they gave me the equivilent model numbers and managed to source them used from Poland.
    Swapped the modules over from the UK lights etc but when turning the car on it has a list of errors, mainly the daytime running lights no longer work and both front indicators do not work, have downloaded Orbit and these are the errors below:
    CEM-B11D013 - DayTime Running Light Left (DRL)- General Electrical Failures- Circuit open
    CEM-B11DC13 - DayTime Running Light Right (DRL)- General Electrical Failures- Circuit open
    CEM-B123A12 - Left Front Turn Indicator- General Electrical Failures- Circuit short to battery
    CEM-B123A13 - Left Front Turn Indicator- General Electrical Failures- Circuit open
    CEM-B123B12 - Right Front Turn Indicator- General Electrical Failures- Circuit short to battery
    CEM-U100D87 - TPMS Information From HMI / DIM- Bus Signal / Message Failures- Missing message
    Any help and suggestions would be highly appreciated.
    Thank you.
      Most probably incompatible/wrong HCM. What are the part numbers of original UK and the new headlights? And don't mention that you use orbit in the official vdash forum. That's a big red flag! 😉
        Searchy
        Thank you for the heads up about not mentioning the software (can't edit my post)
        I ised my original modules from the UK lights as the replacement headlights did not come with any. Original UK left side part number is 31468665 XC90 LED LHT LHS
        Volvo recommended EU replacement part number is 31677038 XC90 LED RHT LHS
        Original UK Right Hand side (drivers side) part number is 31468584 XC90 LED LHT RHS
        Recommended EU replacement part number is 31677039 XC90 LED RHT RHS
        If you could help in any way I would be so grateful.
          Searchy
          @T5-T6-Schnappi Thank you for the heads up about not mentioning the software (can't edit my post)
          I used my original modules from the UK lights as the replacement headlights did not come with any. Original UK left side part number is 31468665 XC90 LED LHT LHS
            replied to Searchy on last edited by
            @Searchy the HCM for your replacements should have part number 31468411. The original UK ones should have 31395944. So that might be part of your problem. I'm not sure if a software reload is needed when using used parts.
              SOpEL
              wrote last edited by SOpEL
              Hey guys, @T5-T6-Schnappi I think I might have the same issue, could you help me with this?
              I receive:
              HIRL
              Sequence Counter Invalid
              HIRL
              Missing Message
              HIRR
              HIRR
              Missing Message
              after moving my original Signal Drive Units (all 4 modules)
              (31446806)
              to EU headlamps
              31353153 / 31446688.
              Does this indicateincompatible firmware, module programming required,
              or incompatible Signal Drive Units?
              Can VDASH reprogram these modules?
              I did conversion from US to EU which I thought could convert headlights as well but unfortunately not.... which means I kinda "lost" lots of euros on that worthless action I did. 😞
              Thanks in advance!
                SOpEL
                I'm adding fault codes also. So the thing is... should I buy correct HIR units (I guess) or can I flash mine via vdash to work with EU headlamps or if not via vdash is it possible to do it via official vida if I'll found someone near my location?
                  replied to SOpEL last edited by
                  @SOpEL the modules needed for your EU headlights have the part numbers 31395943 (pos. 2), 31395944 (pos. 3), 31395945 (pos. 4), and maybe also 31395946 (pos. 5).
                  Without any guarantee that this is still correct.
                  Vdash can't perform software reloads/updates or configure headlights on SPAs. That's my last state of knowledge.
                  You might be able to clone the HCM software from your old modules with Vdash, but I can't tell you if this will solve your problems.
                  The software seems to be the same on all HCMs. At least the software number for a HCM reload is always 31472823 in my catalogue.
