ECM-6720 after egr+dpf off
2 Posts 2 Posters 14 Views
  • 0 Offline
    0 Offline
    0xballer
    Hello, greetings from Canada. I have a 2008 v50 2.4 d5 that I've blocked off egr and weight reduced the dpf. However after loading any iteration of the optimization for egr/dpf off I continue to get fault 6720 egr flow too high, and if I view live data egr valve movement is being commanded. If anyone has a solution to this I would greatly appreciate it as tuning options here are limited to basically just me.
      Bartas222
      Or maybe just disable it in the ECU?
