229 Posts 121 Posters 66.3k Views
    SkyLxrd
    replied to ZaanTerror on last edited by SkyLxrd
    #186
    @ZaanTerror Hey do you still have the installer? Just got a mongoose cable and I'm looking to use it on my V50
      replied to cleenex on last edited by
      #187
      @cleenex
      I had the same issue with S40/V40.
      It is a bug in the software i can't do anything about it.
      C 1 Reply Last reply
        SkyLxrd
        Absolutely amazing installer with super fast delivery! Thank you very much @ZaanTerror
        • Y Offline
          Y Offline
          you54f
          Hey @ZaanTerror, great work, could you fire me over a link please, I am looking to do a bare metal install to avoid running in a vm on a new car laptop. ty
          Y 1 Reply Last reply
          • C Offline
            C Offline
            cleenex
            #190
            @ZaanTerror Exactly, the issue is with an S40 I. Knowing it does not happen with other models, I'll play a little bit with the installation files.
            • Y Offline
              Y Offline
              you54f
              replied to you54f on last edited by
              #191
              Installed successfully, however vida monitor failed to start. Checked vida db logs and noted it was complaining about compressed files. Changed windows properties on vida folder to save uncompressed. Appreciated the repair function which seeded the databases. However I am stuck trying to login.
              The language in the VIDA installation does not correspond to the language setting for your user name in VIDA Admin. Please contact your local administrator.
              Please contact your local Helpdesk
              I am logging in with EUR, tried Admin, same message. I selected eu-gb as the only language at install time. Maybe this isn't honoured during repair?
              Thanks in advance, btw super slick installer. props
              • Y Offline
                Y Offline
                you54f
                #192
                checked the fk in the languages table
                SELECT TOP (1000) [Id]
                      ,[LanguageCode]
                      ,[Cid]
                      ,[fkLexiconId]
                      ,[Changed]
                      ,[ObjVersion]
                  FROM [AccessServer].[dbo].[Languages]
                grabbed the fk for en-gb
                updated the null fk for language for the users
                UPDATE [AccessServer].[dbo].[Users] SET fkLanguage = '7ADADD64-4810-11D8-84F4-F09EEB920AF1';
                And I am logged in. Looking forward to testing with the car tomorrow. Thanks again!
                • I Offline
                  I Offline
                  ibrahim-mz
                  May the peace, mercy, and blessings of Allah be upon you, Ameen.
                  ​I hope this message finds you all well. First, I would like to thank Allah and @ZaanTerror for the amazing software setup—the installation went smoothly without any issues.
                  ​I am troubleshooting a 2014 Volvo XC90 AWD D5 (D5244T18) and need some guidance.
                  ​Background & Timeline:
                  ​Engine Work: The engine was recently disassembled to replace the piston rings.
                  ​Initial Scanner & Injectors (Launch): Right after the engine overhaul, a Launch scanner reported DTCs related to 3 injectors. We replaced the injectors, but the hard-starting issue persisted (the engine only starts on the 2nd or 3rd attempt).
                  ​VDASH Scan: When reading with VDASH, the following codes were present:
                  ​P034100 (Camshaft Position Sensor Circuit Range/Performance)
                  ​CEM-9C03 (Antenna Ring Signal Missing)
                  ​Current VIDA Scan: Scanning with VIDA revealed a different set of communication codes:
                  ​CEM-DF17 – CAN-H High-Speed Network Incorrect Signal
                  ​TCM-U000100 – High-Speed CAN Communication Bus
                  ​HCM-U012987 – Lost Communication With Brake Control Module (BCM)
                  ​CEM-9C03 – Antenna Ring Signal Missing
                  ​Additional Notes:
                  ​The battery is currently weak/degraded, and we have been jump-starting the car using a donor vehicle.
                  ​The engine hard-starting (2nd/3rd attempt) and the DTCs all started right after the piston ring replacement and head reassembly.
                  ​Has anyone experienced a similar issue? Could a pinched wiring harness/ground fault near the cylinder head or low voltage during cranking be pulling down the HS-CAN bus and triggering the CMP sensor error?
                  ​Any advice or troubleshooting steps would be greatly appreciated!
                  N 1 Reply Last reply
                    natito
                    replied to ibrahim-mz on last edited by
                    #194
                    @ibrahim-mz Hi, did they send you the installer? They still haven't sent it to me and I need it; could you send it to me, please?
                    I Z 2 Replies Last reply
                    • I Offline
                      I Offline
                      ibrahim-mz
                      replied to natito on last edited by
                      #195
                      @natito Yes, I received it, but I recommend sending a private message to @ZaanTerror.
                        #196
                        @natito
                        I already send it in chat.
                        • Y Offline
                          Y Offline
                          you54f
                          working fine reading the car but i get a null pointer exception when loading the information tab or via a dtc -> fault tracing. i also have this on another version of vida, so unsure if these are meant to work. looks so on vida youtube videos
                            Dippa
                            Installation went well and provided guide was easy to follow. Vida seems to work even with my native language, except that zoom error with network view. Latest windows 11 and updates as of 9/2026. My cheap china jlr2534 pro cable doesn't seem to work with win 11 and it won't read anything with vida, i can see it with vida but can't read vin or won't connect with hand written vin. Also tested the cable with Vdash and it reads vin but won't connect further. Later tested both programs with my friends mongoose cable and it worked fine so i have to order new one. Very much thanks for this package!
                            • G Offline
                              G Offline
                              Glenn.M
                              Er Da en venlig sjæl da kan hjælp med at installer programmet på min computer. Via fjernstyring. Da jeg ikke kan få min til at gør det. Og har givet op nu. Den vil bar ikke en skid. Skiv på Mail glennknudsen1@gmail.com Vis du / jer. vil hjælpe mig. Til det har Vida Tester har. 🙂 M.v.h Glenn
                                Raidalas
                                Working perfectly with win 11 + rep to this guy for even helping live 🙂
                                • 0 Offline
                                  0 Offline
                                  0laf
                                  Runs great here. 🙂
                                  • Y Offline
                                    Y Offline
                                    you54f
                                    #202
                                    Just to say, that I have reinstalled it on another machine, and able to open the information tab without getting null pointer exceptions. Will take a look at my original install to see if I can resolve.
                                    Thanks again, this is an outstanding contribution to the Volvo community
                                      NJ
                                      Hi ZaanTerror.
                                      Would like to test run your program.
                                      Questions first, will this be able to install straight on a windows 11 laptop, and will it also be able to be connected to internet whiles having the program installed or will this corrupt anything?
                                      Many thanks and regards!
                                      0 1 Reply Last reply
                                      • Y Offline
                                        Y Offline
                                        you54f
                                        #204
                                        removed and reinstalled on the first machine i tried ( panasonic toughbook fz-g2 ) and the java errors are gone on the info tab. thanks again
                                        • 0 Offline
                                          0 Offline
                                          0laf
                                          replied to NJ on last edited by
                                          #205
                                          @NJ said in VIDA 2014D/2015A Windows 11:
                                          Hi ZaanTerror.
                                          Unless you have a webserver on your laptop it will run just fine.
                                          • 12
