Help Needed – SRS Airbag Fault (B00012A) Still Not Fixed After Replacing ECU and Using VDASH
1 Posts 1 Posters 509 Views
    MarwanSUL
    I’m really hoping someone here can offer insight because I’ve tried everything I can think of, spent a fortune, and I’m still stuck with a non-functional SRS system and other VDASH-related problems.
    The Core Issue:
    I’ve been trying to fix a persistent SRS airbag fault (B00012A) on my Volvo XC90 (driver’s airbag circuit range/performance). So far I’ve:
    • Replaced the driver’s airbag (same part number).
    • Verified the clock spring is working.
    • Had the wiring professionally checked – no faults.
    • Even tried using a resistor to simulate the airbag – same fault returned.
    The conclusion was: maybe the SRS ECU is faulty.
    What I Tried Using VDASH:
    I subscribed to VDASH and requested the PIN originally to disable the Trailer Module (TRM) — but that also failed, even after unlocking with the correct PIN.
    Then I moved on to SRS configuration using VDASH:
    Equipment:
    • Started with VOE Ethernet OBD, but it kept failing on key features.
    • Upgraded to the Super J2534 cable (officially listed as compatible by VDASH).
    SRS ECU Configuration Attempts:
    1. Original SRS ECU, Paid for ECU Configuration
    • VDASH showed “configuration successful” after ~30 seconds.
    • But nothing changed. Fault code B00012A still there.
    2. Donor SRS ECU (same part number)
    • Paid again to configure this one.
    • Same story: quick “successful” message but no change.
    • Airbag light started flickering, and I got a VIN mismatch + same B00012A fault.
    I then reinstalled the original ECU, defeated, with no improvement.
    Other Ongoing Problems:
    • I cannot restore CEM to original values — VDASH always gives a “can’t read ECM data” error.
    • I cannot clone ECUs — dropdown is empty even when all hardware is connected and the car is powered properly.
    • VDASH says “successful,” but it doesn’t seem to actually write or change anything.
    • Feels like I’m stuck in a loop with no real progress, despite the “green lights” and power all reading correctly.
    My Questions:
    • Has anyone fixed B00012A through VDASH or another method?
    • Could the SRS ECU store airbag serial data, and mismatched values are causing this?
    • Has anyone else gotten VIN mismatch errors when swapping a “compatible” SRS ECU?
    • Why would configuration complete in seconds without any visible effect?
    • What does the “can’t read ECM data” error actually mean? Could it block other functions?
    • Any recommended Volvo diagnostic tools that actually work?
    If anyone’s been through something similar or can give any guidance, I’d truly appreciate it. I’ve already invested a fortune and a lot of time — I just want to get the car working safely again.
    Thanks in advance,
    Marwan
