ECM-A610
3 Posts 3 Posters 435 Views
  • W Offline
    W Offline
    wenger
    Hello!
    Im having trouble with the code ECM-A610 ADM after replacing 3 of 4 injectors. I have not been coding the "new" injectors, can this be the issue? The car runs fine, but will go in limpmode when the code appears.
      I was driving V50 2011 with new injector for some time without any issues as well. Coded the injectors at some point, but haven`t seen any difference. For some cars/platforms it seems to be mandatory for normal functionality, but not sure if this is a must for the P1 platform.
        replied to wenger on last edited by
        @wenger did you use new or rebuild / remanufactored injectors and the correct parts? Here https://d5t5.com/article/volvo_diesel_injectors you can find some info regarding injector coding.
