NEED HELP, URGENT Volvo XC60 Airbag Configuration Problems U230056 Fault Code
12 Posts 3 Posters 3.4k Views
    replied to jv on last edited by
    @jv did you compare the software numbers of the old and new module? Same hardware doesn't mean same software.
    Did you do any configuration changes besides SRS reconfiguration?
    Did you have a powerfull enough charger attached to the car while running vdash?
    Did the donor car have exactly the same safety features than your car? U230055/U230056= wrong configuration / missing hardware or sensors.
    J 1 Reply Last reply
      jv
      replied to 2009 S80 T6 Owner on last edited by
      @2009-S80-T6-Owner Configuration Fault
        jv
        1. I compare only Hardware Number
          2.No, only SRS config function
          3.Yes, Stable 13.8 Volts
          4.I don't think so, the donor car was an XC90 and mine is an XC60. But, as I said, the sensor faults disappeared after I did the Configuration.
          @jv vdash isn't 100% bullet proof. It's possible that the reconfiguration messed something up. Your codes basically mean that the software configuration isn't compatible with the hardware of your car.
          This can be caused by a wrong CEM configuration or wrong software in a module. I don't know what the vdash SRS wizard actually does and if it tampers parameters in the CEM or SRS, but it's possible that it didn't work as intended. It's also possible that your car hasn't been at the dealer for a longer time and lacks some software updates, while the donor module had newer software that is incompatible with the rest of your car. You might need to visit a dealer, or someone with an official VIDA subscription, who can look up the fault codes and fault trace to possibly solve your problem if the vdash support doesn't come up with a solution.
          • 2 Offline
            2 Offline
            2009 S80 T6 Owner
            Thank you @jv and @T5-T6-Schnappi. Below are screenshots of the SRS dialog box for 2 different modules which differ only by serial numbers. The software numbers shown are the same for both.
            @T5-T6-Schnappi would those be all the software numbers we need to check when trying to replace an original faulty module with a used module from another car?
            Thanks.
            • 2 Offline
              2 Offline
              2009 S80 T6 Owner
              @jv, how long did it take VDASH to complete the SRS configuration for you? Was the total cost EUR99, assuming you have no subscription? I supposed we will be prompted for payment by the configuration wizard at some point?
              I, too, am considering the possibility of taking this route. So, any insights/experience will be much appreciated.
                jv
                @2009-S80-T6-Owner It will take a few minutes to complete the process. Yes, 99 euros. First you need to pay to recharge, after that you can proceed with the process.
                • 2 Offline
                  2 Offline
                  2009 S80 T6 Owner
                  Thank you @jv! Hope your issue gets resolved soon. Keep us posted.
                    @T5-T6-Schnappi did you clone the software of the old module to the new one before running the SRS reconfiguration? This is mandatory for the process to be successful. Read here https://d5t5.com/article/srs-config
                    • 2 Offline
                      2 Offline
                      2009 S80 T6 Owner
                      @T5-T6-Schnappi, looks like your message was intended for @jv.
                      Assuming "clone the software of the old module" means to clone the flash memory containing the software, my mechanic did that along with the EEPROM, which resulted in lost communication with the SRS module (appears grey in VIDA.) This happened to 2 donor modules and eventually I read a post confirming this will happen when the donor module flash memory is overwritten.
                      I have read some posts from people who spoke with VDASH support that "Configure SRS" only works for new SRS modules.
                      I am puzzled what "clone the software of the old module" involves but haven't heard anything from support yet.
