C30 2010 1,6d
I have two questions:- I have installed Polish language, but only the messages on the clocks are in Polish. The interface on the centre panel is still in English. How can I change this?
- I need to unlock the PIN for CEM, but two options are greyed out (normal decoding or Ai) and I cannot select anything. What am I doing wrong?
Best regards,
Bart
@Bart This option should be also be available under the language tab in the top right corner, when you are connected to the car. More info https://svdns.info/2023/08/27/so-youve-bought-an-import-volvo/
Vdash can't decode your PIN.
You need a VDD https://d5t5.com/eshop/detail/87/vdd-volvo-function-extender or a Modunlock device https://modunlock.com/wp/shop/ for this.
Or you have to try again if AI decoding is available for your car, which currently is only active at D5T5 office hours Mon-Fri 9:00 - 16:00 - CET. -
Hi, what is the problem with the PIN decoding? Not supported for this car, or the service is cancelled in general?
Thank you for your answers.
I still don't understand something. Vdash cannot decode the PIN, OK, but I replaced the screen on the centre panel and the old panel was in Polish and had the inscription D5T5, so someone probably made it Polish, Vdash? So where am I going wrong (Polish version)? Another question: will I get the PIN for CEM from the Volvo dealer?
Best regards,
Bart -
For the language change there is no need for CEM decoding.
And NO, the dealership will not provide the PIN. -
Streaming through BT I suppose, and also I suppose you have the BT module (otherwise the process will be very complicated), but limited only for phone calls. In that case maybe it will be possible to make this configuration, but after the PIN decoding.
That's why I replaced the screen and BT module with one that should enable streaming. After replacing the modules, everything works, so someone had already disabled the MOST lock. There was a Polish screen with the inscription D5T5, so I assume that someone had already tampered with the car.
I understand that VDASH does not have the PIN for my car, even though I think the PIN had already been extracted earlier. I will see if it is possible to extract the PIN using the AI method, but as mentioned earlier, I have to do it during business hours, i.e. Monday to Friday. -
Perfect! Configuration only, or also hardware retrofit?
