157 Posts 73 Posters 37.3k Views
    @ZaanTerror finally found the time to do some testing of your latest version (03.02.26 from MEGA).
    Clean install worked flawless, as usual.
    Playing a little on a 2001 S60 and a 2018 V60CC(P3) didn't bring up any problems. Diagnostics, parts catalogue and service functions were working as expected.
    Good work!!!
      @T5-T6-Schnappi : so the 2018 models are recognized in this version of Vida? it's not limited to 2015 only?
        #16
        @sizan this version is patched to support some P1 and P3 cars up to 2019. But for my V60CC with a VEA engine I have to use a workaround. Cross Countrys are only supported in the US partner group, and only with 5 cylinder petrol engines. The workaround is explained here https://svdns.info/2022/01/15/using-vida-2014d-with-an-unsupported-vin/
          OGhenry
          Working good right from the start with my laptop, nice work!👍
            26-02-2026 UPDATE:
            Improved installation and uninstallation sequence.
            Upgraded to SQL Server 2025 Standard Developer.
            Upgraded JBoss EAP to version 8.1 update 4.(latest version available today)
            The download link will stay the same, when you download again you will have the newest version.
            • PinkyRoseP Offline
              PinkyRoseP Offline
              PinkyRose
              Will take time for me to try it out on my volvo but it detects my DiCE and the installation was easy, thank you for making it so simple.
              • U Offline
                U Offline
                UlfB
                Thank you for this release of Vida together with Windows 11. It was just to unzipping the file and starting the installation, and after a while everything was up and running since you had also attached the other files that you otherwise had to download yourself.
                So again, a BIG THANK YOU for this 👍🏆.
                  Vreaper
                  Id like to try this out, Currently have been using a 2015a version on windows 10 ltsc machine.
                  I want to update my surface pro to windows 11 though, so would like to try this version out there.
                  Ill send you a Pm @ZaanTerror
                  Cheers
                    Trixen
                    Big thank you for this! Tested on Windows 11 and starts up without issues, haven't yet tested it on a car! Is it possible to have a local EWD instead of the online one if there is a bad internet connection? Not so necessary! 🙂
                      Yes if you install the original EWD CD-Rom it will overwrite the online EWD.
                      Please leave a review at the original post so others can see you like it! 😄
                        Sorry i thought i was in chat 😄 Thank you for the review!
                          Vreaper
                          it works great on Windows 10/11 LTSC IoT. Thanks alot for the release, I notice quite abit is upgraded, uses arbortext instead of isoview ect.
                          Only issue ive had thus far, not sure if anyone else can chime in~ I did a fresh install of w11, and then optional features i setup 3.5 net. and let microsoft download it. then i let vida installer work, everything seems to work.
                          ~sometimes the Arbortext( im guessing) will load up the image of the modules all zoomed in, and i cannot zoom it back out. my temp~ fix has been to just relaunch it then itll show up as the regular size modules layout.
                          Very small gripe to me, But anyone else notice that? I often need to see if the modules are all online, On previous versions ive seen itll read all the modules but the ecm. so i like to be able to see all the modules on that small little screen, Another side~ fix is if i load up say, Network itll glitch the network image to be zoomed in. but both faults, and the activations portion will show me the proper sized overlay.
                          I can post a photo just incase this sounds like insanity.
                          But thanks so much @ZaanTerror for the great release. Im assuming the issue im having is on my end, just not sure what could be causing it.
                          Z T5 T6 SchnappiT 2 Replies Last reply
                            replied to Vreaper on last edited by
                            #26
                            @Vreaper Thank you for the review! I will look into the NET Framework prerequisite.
                            I think youre issue with the image(s) has to be arbortext isoview.
                            Isoview is responsible for showing the modules and parts images.
                            You could try uninstalling Arbortex Isoview 7.1 and installing another version of IsoView and see if it resolves the issue.
                            The latest version is 7.3 and the original VIDA version is 4.0.
                              sangcXL3
                              Ive just installed it on mu windows 11 home.
                              It works fine!
                              Except the minor zoom issue in the ecu modules as per others experienced. But that really does not matters.
                              Other minor issue is on the visual also,
                              When i perform data trending under vehicle communication, the trend scales number seems to be overlap.
                              But anyways, the installation is actually my biggers concern and thank you for compiling the installation file so well. The single-click setup works perfectly and makes the whole process very smooth and convenient. I really appreciate the effort you put into making it simple and reliable.
                                Otisitswe
                                Thank you very much @ZaanTerror it worked on my windows 11 pc.
                                  repeq
                                  #29
                                  This post is deleted!
                                    JohnieBraaf
                                    @ZaanTerror, you are a true hero. Installed this both on a VM as bare metal machine (Windows 10), both installed flawlessly. The application is confirmed working and I was able to reset my DTC code at last. Many many thanks!
                                      repeq
                                      I get a database error when starting the computer, of course Vida doesn't start.
                                        replied to repeq on last edited by
                                        #32
                                        @repeq
                                        Did you let my installer handle the SQL installation? If yes verify that SQL Server Service is started and running.
                                        If you installed SQL with the setup from ISSetupPrequisites folder uninstall VIDA and SQL Server and start installation again.
                                          #33
                                          @Vreaper I have the same issue with the zoomed in isoview window, but only under Win 10 on a laptop that had another version of VIDA installed before I switched to ZaanTerrors Version. I can zoom in and out with the mouse wheel and with a pinch-and-zoom gesture on the trackpad. But here comes the weird part, if I boot this laptop from a Windows to go USB drive with Win 11 and clean install of VIDA, this issue doesn't occur. So my conclusion is, there is something left from a previous version of Isoview or VIDA that causes this. Maybe a registry entry or some sort of config file.
