129 Posts 60 Posters 18.0k Views
    Vreaper
    it works great on Windows 10/11 LTSC IoT. Thanks alot for the release, I notice quite abit is upgraded, uses arbortext instead of isoview ect.
    Only issue ive had thus far, not sure if anyone else can chime in~ I did a fresh install of w11, and then optional features i setup 3.5 net. and let microsoft download it. then i let vida installer work, everything seems to work.
    ~sometimes the Arbortext( im guessing) will load up the image of the modules all zoomed in, and i cannot zoom it back out. my temp~ fix has been to just relaunch it then itll show up as the regular size modules layout.
    Very small gripe to me, But anyone else notice that? I often need to see if the modules are all online, On previous versions ive seen itll read all the modules but the ecm. so i like to be able to see all the modules on that small little screen, Another side~ fix is if i load up say, Network itll glitch the network image to be zoomed in. but both faults, and the activations portion will show me the proper sized overlay.
    I can post a photo just incase this sounds like insanity.
    But thanks so much @ZaanTerror for the great release. Im assuming the issue im having is on my end, just not sure what could be causing it.
    Z T5 T6 SchnappiT 2 Replies Last reply
    • Z Online
      Z Online
      replied to Vreaper on last edited by
      #26
      @Vreaper Thank you for the review! I will look into the NET Framework prerequisite.
      I think youre issue with the image(s) has to be arbortext isoview.
      Isoview is responsible for showing the modules and parts images.
      You could try uninstalling Arbortex Isoview 7.1 and installing another version of IsoView and see if it resolves the issue.
      The latest version is 7.3 and the original VIDA version is 4.0.
        sangcXL3
        Ive just installed it on mu windows 11 home.
        It works fine!
        Except the minor zoom issue in the ecu modules as per others experienced. But that really does not matters.
        Other minor issue is on the visual also,
        When i perform data trending under vehicle communication, the trend scales number seems to be overlap.
        But anyways, the installation is actually my biggers concern and thank you for compiling the installation file so well. The single-click setup works perfectly and makes the whole process very smooth and convenient. I really appreciate the effort you put into making it simple and reliable.
          Otisitswe
          Thank you very much @ZaanTerror it worked on my windows 11 pc.
            repeq
            #29
            This post is deleted!
              JohnieBraaf
              @ZaanTerror, you are a true hero. Installed this both on a VM as bare metal machine (Windows 10), both installed flawlessly. The application is confirmed working and I was able to reset my DTC code at last. Many many thanks!
                repeq
                I get a database error when starting the computer, of course Vida doesn't start.
                • Z Online
                  Z Online
                  replied to repeq on last edited by
                  #32
                  @repeq
                  Did you let my installer handle the SQL installation? If yes verify that SQL Server Service is started and running.
                  If you installed SQL with the setup from ISSetupPrequisites folder uninstall VIDA and SQL Server and start installation again.
                    #33
                    @Vreaper I have the same issue with the zoomed in isoview window, but only under Win 10 on a laptop that had another version of VIDA installed before I switched to ZaanTerrors Version. I can zoom in and out with the mouse wheel and with a pinch-and-zoom gesture on the trackpad. But here comes the weird part, if I boot this laptop from a Windows to go USB drive with Win 11 and clean install of VIDA, this issue doesn't occur. So my conclusion is, there is something left from a previous version of Isoview or VIDA that causes this. Maybe a registry entry or some sort of config file.
                      repeq
                      I had to open Port 1433 and SQL Browser (UDP 1434) in the win firewall and release port 80 for Vida and block the automatically starting World Wide Web Publishing Service. Now it seems to work.
                      K 1 Reply Last reply
                        sangcXL3
                        #35
                        @T5-T6-Schnappi would you mind to share how you remove previous installation file on your win10? I have another laptop with win10 that i installed a failed vida previously, im trying to reinstalled with @ZaanTerror installer, but i could not proceed ad the vida does not recognize to be installed in the setup
                          repeq
                          I had the same problem with SQL libraries, it even seemed impossible to get the post to work, but finally, using artificial intelligence, I managed to do it.
                            replied to sangcXL3 on last edited by
                            #37
                            @sangcXL3 I first stopped VIDA Monitor and all SQL services, then I uninstalled the old VIDA, everything related to SQL, and Isoview with their uninstallers. Rebooted the computer. And then I manually deleted all folders related to VIDA, Volvo, Isoview and Microsoft SQL. This is quite tricky as lots of those folders are hidden. Look into the subfolders of C:/ProgramData/ (hidden); C:/users/{yourWindowsusername}/AppData/ (hidden) press Windows-key together with R and then simply enter AppData and press Enter to open this folder; C:/Program Files (x86)/Common Files/; C:/Program Files/Common Files/. I also removed several registry keys in HKLM\SOFTWARE\ and HKLM\SOFTWARE\WOW6432Node.
                            After another reboot the new VIDA installed without problems.
                              Vreaper
                              I actually was able to solve the issue on my win11 machine
                              for anyone else with the same issue
                              try setting the resolution under 1440x900 and have absolutely no scaling. i think scaling 150% on the 1920x1080 resolution was causing it for me
                              when i lower resolution under 1440x900 it never happens.
                              I think vida back then wasnt used to running on high resolutions, atleast with dpi scaling.
                                #39
                                @Vreaper the old VIDA indead had problems with high resolutions. You had to use the right mouse button to select ecus in the network and communication tab. But zooming was never a problem.
                                  RuRU
                                  @ZaanTerror Thank you so much.
                                  I install your version, and at least for my case is perfect. I didn´t find yet any problem. Also, it was so easy to install it.
                                    repeq
                                    #41
                                    @ZaanTerror I installed it and have been using it for a while now, it works great, when could I get a new version of what you're commenting on?
                                      Vreaper
                                      ive got a new issue. i dont know what happened. my surface pro 7 seems to have bricked the vida.
                                      just says starting when i boot up.
                                      how can i look at whats stopping the server from starting up?
                                      • Z Online
                                        Z Online
                                        There are VidaMonitor logs in the C:\VIDA\System.
                                        But i think you can fix the issue in 2 ways:
                                        1 - enable Vidamonitor at windows startup and reboot the system so VidaMonitor is started with System rights.
                                        2 - uninstall VIDA (dont uninstall SQL!), install again and reboot
                                          Vreaper
                                          #44
                                          @ZaanTerror yeah it works flawlessly on my toughpad too.
                                          reinstalling it worked,
                                          if it breaks again ill try to track whats happening better on the system day to day, and when or if it bricks the vida again where i have to reinstall ill atleast report back and share what did it. at this point in time seems like some kinda update. or theres this iobit advanced systemcare software i figure that kinda program coulda messed with the vida unknowingly
                                          but ill figure out what bricked it on the surface just incase anyone else runs into the problem
