49 Posts 20 Posters 3.2k Views
    replied to sangcXL3 last edited by
    #37
    @sangcXL3 I first stopped VIDA Monitor and all SQL services, then I uninstalled the old VIDA, everything related to SQL, and Isoview with their uninstallers. Rebooted the computer. And then I manually deleted all folders related to VIDA, Volvo, Isoview and Microsoft SQL. This is quite tricky as lots of those folders are hidden. Look into the subfolders of C:/ProgramData/ (hidden); C:/users/{yourWindowsusername}/AppData/ (hidden) press Windows-key together with R and then simply enter AppData and press Enter to open this folder; C:/Program Files (x86)/Common Files/; C:/Program Files/Common Files/. I also removed several registry keys in HKLM\SOFTWARE\ and HKLM\SOFTWARE\WOW6432Node.
    After another reboot the new VIDA installed without problems.
      Vreaper
      I actually was able to solve the issue on my win11 machine
      for anyone else with the same issue
      try setting the resolution under 1440x900 and have absolutely no scaling. i think scaling 150% on the 1920x1080 resolution was causing it for me
      when i lower resolution under 1440x900 it never happens.
      I think vida back then wasnt used to running on high resolutions, atleast with dpi scaling.
        replied to Vreaper last edited by
        #39
        @Vreaper the old VIDA indead had problems with high resolutions. You had to use the right mouse button to select ecus in the network and communication tab. But zooming was never a problem.
          RuRU
          @ZaanTerror Thank you so much.
          I install your version, and at least for my case is perfect. I didn´t find yet any problem. Also, it was so easy to install it.
            repeq
            replied to ZaanTerror last edited by
            #41
            @ZaanTerror I installed it and have been using it for a while now, it works great, when could I get a new version of what you're commenting on?
              Vreaper
              ive got a new issue. i dont know what happened. my surface pro 7 seems to have bricked the vida.
              just says starting when i boot up.
              how can i look at whats stopping the server from starting up?
                There are VidaMonitor logs in the C:\VIDA\System.
                But i think you can fix the issue in 2 ways:
                1 - enable Vidamonitor at windows startup and reboot the system so VidaMonitor is started with System rights.
                2 - uninstall VIDA (dont uninstall SQL!), install again and reboot
                  Vreaper
                  #44
                  @ZaanTerror yeah it works flawlessly on my toughpad too.
                  reinstalling it worked,
                  if it breaks again ill try to track whats happening better on the system day to day, and when or if it bricks the vida again where i have to reinstall ill atleast report back and share what did it. at this point in time seems like some kinda update. or theres this iobit advanced systemcare software i figure that kinda program coulda messed with the vida unknowingly
                  but ill figure out what bricked it on the surface just incase anyone else runs into the problem
                    SKanev
                    Works absolutely brilliantly, one click and everything installs as easy as can be and runs perfect, genuinely outstanding work, tried it on a Dell Precision 5540 running W11 Pro (Version 10.0.26200 Build 26200)
                    with a JLR V168 (pro) off AliExpress with the D5T5 drivers on a 2001 S60
                      Rikos92
                      This is the best Vida I have used in all the years, thanks for the work done.
                        sineDko
                        I have found myself in need of new VIDA after upgrading my workshop notebook.
                        This realease as very good and does everything one needs from VIDA. Thank you
                          #48
                          @Vreaper Don't put too much time in this my next version has a new VidaMonitor i created and will fix this issue.
                            rewned99
                            I installed it in 2 VirtualPc in Vmware 25h2..., the installation went fine and it's working so far. I'll connect it to the car and let you know...
