VDASH not connecting to the XC40 (CMA)
Scheduled Pinned Locked Moved CMA (XC40, Polestar 2)
6 Posts 2 Posters 2.4k Views
  • E Offline
    E Offline
    evov
    I bought your J2534 cable. Installed the VDASH but the software doesn't detect the car. The vehicle is 2022 Volvo XC40 T5. The car is up and running and there is no issue with the OBD port. Please advise.
    T5 T6 SchnappiT 2 Replies Last reply
      replied to evov on last edited by
      @evov did you install the drivers?
      https://d5t5.com/eshop/sw/J2534_Driver_x64.msi for 64bit Windows
      https://d5t5.com/eshop/sw/J2534_Driver_x86.msi for 32bit Windows
        replied to evov on last edited by T5 T6 Schnappi
        @evov and engine should not run when you connect vdash. Ignition needs to be in pos. II, ingnition on, engine not running.
        • E Offline
          E Offline
          evov
          I installed the driver (x64). Tried your suggestions but still no connection to the car.
            Do the LEDs in the adaptor light up, when connect it to the car?
            Where did you buy your adaptor?
            Did you try a different USB port?
            Did you try to simply reboot your computer, as Windows sometimes locks up certain files until you reboot it.
            Did you use the correct connecting order? 1.Adaptor in the car, 2. Ignition on, 3. Cable in the USB port.
            Do you have any third party anti-virus software installed? If yes, disable, or even better, uninstall it.
            You can also try a re-install. Uninstall Vdash, reboot your computer, download and install a fresh copy of Vdash https://d5t5.com/sw/vdash.exe and see if it updates itself after starting it.
            • E Offline
              E Offline
              evov
              Received VOE with ethernet adapter and the Vdash connected to the car without issue. I have the Vdash lite account and it seems I can't run even basic diagnostic. Do I need to buy subscription for any reading?
