OBDLink EX Compatibility
drivers
2 Posts 2 Posters 1.0k Views
    Styles Bitchley
    I had read online that I could use the OBDLink EX to connect to VDASH. It's readily available here in Canada via Amazon so I bought one. However, I can't make it connect correctly. When I use the native drivers, VDASH says the drivers are outdated or forbidden. When I use the "Super J2534 / Mongoose JLR" driver, the computer will not connect to the car. Has anyone made the OBDLink EX work?
      OBDlink does not work. Regardless what you try. You need J2534 compatible hardware.
