TFT Dim , instead of eco and power, can we see boost value
2 Posts 2 Posters 13.2k Views
  • E Offline
    E Offline
    Erin
    Hi to everyone,
    I am new to d5t5 family,
    I just purchased the TFT upgrade and will complete the retrofit this weekend (ı hope)
    my question is, is there any possibility to change the eco and power display sections to boost value. by that way we can see if there is any issues wıth the turbo, or it may be any ather pressure value like transmission or, oil pressure.
    hope it makes sense
    regards
    Erin
      Not possible. There are various OBD HUD displays for this, or countless apps for mobile phones like Car Scanner ELM OBD2, that just require an OBD-dongle like a vLinker MC+ or OBDLink MX+, and show all parameters that are provided by the ECUs that are installed in your car. Except oil pressure. Volvo uses simple oil pressure switches on most of their engines that switch on/off at a specific pressure value and give a warning when the pressure is below a specific pressure value. If you want to see absolute pressure values, you have to install an aftermarket solution for that.
