DTC DIM-U300045
12 Posts 8 Posters 7.5k Views
  • F Offline
    F Offline
    fridborg
    Hello Guys :0)
    I wonder if someone has ever got a problem with the adaptive cruise control?(XC60 2016 D4)
    I got the fault code DIM-U300045.
    I can only use the Cruise control for about 5mins then it shuts off telling that it is not reacheable.
    It seems like it is a compatibility problem?
    The ODO meter has never been modified or so(as I could see in many comments that can be a reason).
    The ECM is changed as it has a water damage so the only thing is done is that the old one was copied(cloned?) and replaced.
    Otherwise everything works as it should.
    Do you have any Idea/suggestion what can be done ?
    Many thanks in forehands to you all and Wish You A Happy New Year!!!
    Best regards,
    Josef
    • D Offline
      D Offline
      D5T5 ok2ucx
      Hi, this DTC occurs when the DIM firmware actually IS modified. We have seen several DIMs like that, and once the proper(OEM, untouched) DIM firmware is reloaded, the original mileage appears.
      In your case, we can just check your DIM - when possible - do the "Clone DIM" operation in VDASH, but only the first (read) part of it, then just cancel writting. Later, I will review/compare your firmware.
      Pavel
      B 1 Reply Last reply
      • D Offline
        D Offline
        D5T5 ok2ucx
        Hi, found your DIM readout. That file IS modified, your "mileage" is 193xxx km. but the DIM reports no values for other units. I have prepared the correct file for your DIM that should reveal the truth, if you like.
        Once loaded, the DTC should disappear and the (now hidden) mileages from ECM, DDM, PDM, SRS, BCM and CEM should appear there.
        Pavel
        F 1 Reply Last reply
        • F Offline
          F Offline
          fridborg
          replied to D5T5 ok2ucx on last edited by
          @D5T5-ok2ucx
          Many Many Many THANKS Pavel!!!!Really appreciate your kindness and help!!!
          I have done as You suggested and loadet the new orig software and it works fine!!!
          (I bought this car defective with water in the engine Ecu and before I wasn't know that vdash exist so I brought the old ecu to a locksmith to clone but no more so so how my story started)
          Have nice weekend!!!!
          Best regards,
          Josef :0)
            Stefan123
            Hi. I have the same problem.
            I have read DIM two days ago.
            Could you check if you have oryginal
              AndreiS
              Hello guys,
              Got another one with the DIM-U300045 DTC. I bought it used and it has the DIM menu in Romanian. The car itself was brought from the Netherlands, so there is no way they delivered it like this from the factory - for sure some "handy" guy fiddled with it.
              Having done the DIM read, would I be able to have a look in the dump and maybe figure it out or could one of you help me ?
                Beared81
                @D5T5-ok2ucx said in DTC DIM-U300045:
                Pavel
                do you you attain the original and load it. Need 31499926
                • G Offline
                  G Offline
                  Gorky571818.
                  Hello.
                  Adaptive cruise control problems? (XC60 2016 D4)
                  I got a fault code DIM-U300045.
                  I can only use the cruise control for about 7 minutes, then it turns off, saying it can't be used. I had the mileage reset, how can I restore the DIM. I cloned the DIM
                    replied to Gorky571818. on last edited by
                    @Gorky571818 This code has nothing to do with your problem. There is most probably a CVM code for a misaligned FSM present in your car.
                    • G Offline
                      G Offline
                      Gorky571818.
                      I only have one error dim. and I found out that the mileage was reset from 150k to 120k, how can I reset everything back?
                      • G Offline
                        G Offline
                        Gorky571818.
                        Maybe someone can help here?
                          CristianMD
                          DIM-U300045 error fix needs cem pin ?
