Turn off START/STOP Permanently in VDASH.
4 Posts 2 Posters 1.3k Views
    Belos
    Hi! I have purchased the service to have my car's CEM PINCODE unlocked. And I have purchased a Subscription called FLAT CONFIG, by Vdash.com But when I go into the Vdash program and do my configuration, to turn off START/STOP Permanently in my car, a Red Text appears that says: ((Processing of Items ended with an error)). And in the Window’s where you see how a scale grows, the further in the programming it has come. There you see that the Programming is interrupted with the Text: ((PATCH FINISHED)). Can someone help me with this? And last night I charged my Starter Battery. Now that I am in Vdash, it shows in the top right corner that the Starter Battery is at 12.0 Volts, now that the Engine is off. Do you think that is too low? Can Vdash program feel that the Charge Level in my Starter Battery is too low? I started by disconnecting the Negative Terminal for about 11 Minutes, on the Starter Battery first. Vdash Support wrote that I would try to do this. And then try in Vdash again. But it still didn't work. That didn't help. I'm posting two pictures here. Is there anyone here who recognizes this problem, in Vdash. Thank you! From Tommy.
      replied to Belos on last edited by
      @Belos Did you receive a message/email that your pin code was successfully cracked and added to the vdash database?
      You should always have a powerfull charger connected while you perform configuration changes. And after changing configurations, you should leave the car alone and locked for at least 15 minutes. What adapter do you use to connect your car and computer?
        Belos
        Hi! Many thanks! For quick help. I have received a message with WhatsUpp, that the Support writes that he has added a Pin to my VDASH Account. And it says in my Vdash, "Configuration changes are supported"
          Belos
          I wonder if it is possible to post pictures here? And "If YES" How do you do it?
