Amp replacement
Scheduled Pinned Locked Moved Others troubleshooting / Ostatní problémy
4 Posts 2 Posters 995 Views
  • D Offline
    D Offline
    danielraistrick
    Bought the car and was advised the amp was damaged. He replaced with a different amp and wasnt even for this car. Bought VCC p/n 31215615. This is the same amp which was damaged.
    In replacing the stereo works for 1 minute then turns off and the sat/nav or stereo stops working.
    When you stop lock the car and then unlock it does the same.
    Was advised it was just a case of a straight switch. Any ideas on what im doing wrong
      replied to danielraistrick on last edited by
      @danielraistrick Did you disable ITP-security in the CEM and IHU?
      • D Offline
        D Offline
        danielraistrick
        I didnt no
          @danielraistrick Then everything works as intended. ITP (Infotainment theft protection) detects a module that doesn't belong to your VIN and shuts down the whole Infotainment.
          You need to decode the CEM pin, IMMO pin and Security pin with vdash, and than you can disable ITP.
          Or you visit a Volvo dealer and ask for the installation of software with the partnumber 31268617, which also disables ITP. But allot of dealers refuse to do this. Atleast here in germany.
