I want to teach in after air compresor and valve block was changed
2 Posts 2 Posters 310 Views
  • L Offline
    L Offline
    LIVIU1995
    hello, i need your knowleadge about hot to start up the new oe volvo air compresor and also valve block... after this things was changed car has low down, and doesn t rise up !
    On a SUB module (suspension module) i don t see any advanced option or other this to do , maybe u could help me with this!
    CAR its Volvo xc90 2016 year 2.4d engine europa
      replied to LIVIU1995 on last edited by
      @LIVIU1995 Is the new compressor working? Did you delete all DTCs after installing the new parts, and did they all disapear? As long as you just changed the compressor, there shouldn't be any calibration needed. If you didn't damage the leveling sensors, you should simply start the car, enable air suspension and drive a little bit.
      If Vdash doesn't show advanced options for specific ECUs, those functions are either not implemented jet, or your account isn't unlocked to access them. "sponsored" accounts for example, don't have full access to all functions. You could also try a mobile phone app called V-Tool https://v-tool.app/ in combination with a vLinker MC+adapter. This app is similar to Vdash in terms of diagnostics and service functions, but seems to support more functions on some cars.
